power antenna
Old Mar 21, 2006 | 08:04 PM
imnotplutonium's Avatar
Default power antenna
has anyone used the antenna-x from ebay? if so did it work pretty good, i am wanting to convert my non-power antenna to a power antenna and this seems to be a good price. anyone?
Old Mar 21, 2006 | 10:16 PM
VIP1's Avatar
Copy & Paste Moderator
I don't know what power antenna you are talking about on ebay, but here is a write-up and GM part number for the stock power antenna (which you can get from www.gmpartsdirect.com):
http://www.blackcamaro.com/antenna.htm
Old Mar 21, 2006 | 10:29 PM
i was talking about this one
http://cgi.ebay.com/ebaymotors/Power...47266474QQrdZ1
it is cheaper than the factory one and i wanted to see if it worked just as well, but thanks for the info, i just might end up getting the factory one if no one has used this alternative
Old Mar 22, 2006 | 12:41 AM
2MuchRiceMakesMeSick's Avatar
Looks pretty cheap to me.
Id go with the gm parts just because the fit and filament will probably be alot better.
Old Mar 22, 2006 | 09:57 PM
VIP1's Avatar
A new GM unit is about $78 on GMPartsDirect.com
You can often find used ones on ebay for $50.
(Funny thing is that new ones cost about the same as on GMPartsDirect.com)
I know its more expensive than one you posted, but its a genuine gm part that is designed to fit.
Old Mar 23, 2006 | 01:28 AM
loyolacub68's Avatar
Your going to save yourself a lot of time with bolting it on there if you just buy the GM unit.
Old Mar 23, 2006 | 10:40 AM
ok cool, i'll just go with that then (the gm unit that is)
Old Mar 23, 2006 | 09:03 PM
VIP1's Avatar
Double check the part number before you buy one.
I seen two different part numbers listed for the power antenna.
Old Mar 25, 2006 | 05:14 AM
2001FireBird's Avatar
VIP1, when you say two differnt part numbers, whats the differnece? Is it different between model trims? like a V6, or v8 antenna?
Old Mar 25, 2006 | 12:21 PM
WhiteBird00's Avatar
Ungrounded Moderator
P/N 10269280 is for 93 thru mid-97. P/N 10402860 is for late 97 and all 98-02 models. I don't know what the difference is.
Old Mar 25, 2006 | 02:27 PM
Mike00ss's Avatar
as stated above i want to say to anyone who is doing this, use http://www.blackcamaro.com/antenna.htm[/QUOTE]
great site.
Old Mar 25, 2006 | 11:17 PM
VIP1's Avatar
I dont know what the difference is either.
Old Mar 25, 2006 | 11:19 PM
VIP1's Avatar
In that case.....there is a 3rd part number:10402859
I have no clue what the difference is, but I have seen that partnumber before. (Thats the partnumber on http://www.blackcamaro.com/antenna.htm)
I found some descriptions in this post:
https://ls1tech.com/forums/showpost....89&postcount=2
from this thread:
https://ls1tech.com/forums/general-maintenance-repairs/336981-lt1-lt4-ls1-ls6-f-body-part-numbers.html
about partnumbers
Old Apr 7, 2006 | 03:05 PM
2001 LS1 SS's Avatar
from this thread:
https://ls1tech.com/forums/showthread.php?t=336981
about partnumbers
10402859 is the only one that will fit the Camaro. 10402860 doesn't fit the Camaro, I believe it is for Firebirds, but not sure on that one. So if you're looking to do this in a 'Bird, that might be the one.
Old Apr 7, 2006 | 03:26 PM
Luna's Avatar
I would just get a stubby little antenna instead of putting a power antenna in. That thing just pisses me off... I hate the sound of it
By Brett Foote | 2026-06-04 05:00:17
