Blinker problem.
Old Apr 6, 2006 | 05:02 PM
musclehead's Avatar
Default Blinker problem.
My left turn signal is acting weird. When applied it stays solid (green) with no blinking. However my right turn signal is working perfectly fine. What is going on here guys? How do I fix this problem?
Old Apr 6, 2006 | 05:53 PM
JaS5902's Avatar
Check you bulbs. That's what mine did when it blew.
Old Apr 6, 2006 | 08:32 PM
WhiteBird00's Avatar
Ungrounded Moderator
Put on your hazard flashers and walk around the car looking for the bulb that doesn't flash. Either that bulb is burned out or the socket is corroded.
Old Apr 7, 2006 | 04:43 PM
musclehead's Avatar
It was a bad bulb. Thx guys. I learned something new about my car.
Old Apr 7, 2006 | 10:31 PM
Duffster's Avatar
HIJACK HIJACK HIJACK. . .I'm stealing this thread. . .
how about when while the blinker is blinking, it decides to stop. . . and about 30 minutes later, it works fine again. . .
been happening to me...
check the other side and it's locked also...
go for a bit w/out using and then try, sometimes solid still, sometimes works. . .
ideas besides possible short somewhere?
btw, hazzards continue to work when the signals lock...
Thanks
Old Apr 9, 2006 | 10:53 AM
Thanks
If both sides stop working at the same time then it is probably the flasher. If one side works but the other doesn't then it can't be the flasher so it is probably a corroded socket or bad wire to one of the bulbs on the side that doesn't flash.
Old Apr 9, 2006 | 08:22 PM
HiTechGent's Avatar
Don't forget to top off your blinker fluid.
http://kalecoauto.com/index.php?main...50da8da487aa8c
Old Apr 9, 2006 | 08:33 PM
ckingcmaro's Avatar
Also, the problem may be solved. Just a heads up, with what happened on my camaro. Water kept getting into the light housing, thus shorting out and busted my bulb, it about completely melted the female wiring housing for the bulb socket. So, i'd watch for that also if your bulb was busted and the housing was melted.
