Damage the tach wire?
Old Apr 16, 2006 | 06:15 PM
LSWannabe's Avatar
Default Damage the tach wire?
When I install my raptor shift light do I have to gouge the tach wire using one of those pinch connectors or is there something else I can do?
Old Apr 18, 2006 | 02:45 AM
LSWannabe's Avatar
to the top
Old Apr 18, 2006 | 10:01 AM
2000Z28M6's Avatar
You can carefully strip it and then solder it. As long as you have a good solid connection it doesnt matter how its held.
Old Apr 18, 2006 | 12:15 PM
01WS6/tamu's Avatar
If you can find them gm makes a crimp connector that you crimp then heat and it will shrink and fill the connection with a heat activated sealer.
Old Apr 18, 2006 | 10:48 PM
SweeTbone's Avatar
I used a "pinch connector" and it's been working fine. I wrapped a little electrical tape around the entire connector once I clamped it down good. The strip and solder is a good idea if you're crafty like that, which me = not crafty like that.
Old Apr 19, 2006 | 08:14 PM
Johnny5's Avatar
If you have a Wal-Mart around you (which most people do) they happen to carry the Posi-Lock connectors.
http://www.posi-lock.com/posiplug.html
Honestly, these are about the easiest thing ever and make a very good, secure connection that is easy to undo if you want to for some reason.
Old Apr 19, 2006 | 11:26 PM
2MuchRiceMakesMeSick's Avatar
I wouldnt cut the wire.
Instead take a razor and carefully remove the insulation from around the wire and solder the new wire onto it. The tack wire remains uncut.
Old Apr 20, 2006 | 11:38 PM
LSWannabe's Avatar
I'll probably check out those posi taps. They have to at least cut through the insulation right???
