Faster Windows?? Upgrade
Just off the top of my head, has anyone considered seeing what voltage your getting at the motors? If there is a drop through the switch or due to skinny wires used in the first place then the lowered voltage will make them slower than they should be. A wiring upgrade or a switch cleaning may be the fix.
i was using the heavy window in comparison to a honda who are notorious for having fast windows. (reason being partly because of the smaller windows.) look up how heavy our windows are just so you can get an idea of the strain our window motors have to withstand
thats a very very good write up on the whole step by step process. the only thing i have to say is on step number 18, he listed the holes you use for the drivers side. it MAY be different for you. (it was for me)
https://ls1tech.com/forums/showpost....1&postcount=18
yea our cars have some huge *** windows....
One is to increase voltage like I mentioned before. Getting almost the full voltage that the battery is at while under load will be very noticable. I bet the stock motors are getting 1 to 2 volts under the batteries level.
The other way would be to change the gearing. The motors use a gear reduction to swap speed for torque. I haven't seen all the components, but I'm sure it would be a lot of work. An easier way would be to adapt another motor which already has a faster gear ratio.
Anyway, I would try upgrading the wiring and clean the switch contacts to reduce resistance and get more voltage to the motor before I tried messing with the gearing. It should make a difference just like the one between having the motor running (14 volts) and the motor off (12 volts). I can certainly see the difference in speed so I make sure to roll them up before turning the engine off.
