Faster Windows?? Upgrade
That may be a 3rd way to make them faster, just swap the motor out with a faster one. Faster and bigger may be even better.
For anyone with an old motor, does it have a sticker with any motor specs such as RPM or amperage?
Has anyone taken apart the switch or thermal control section. I would love to learn more about it.
. It was only $55 and comes with a lifetime warranty. I may go ahead and do the other side just to get the speed. recently my EBAY motor $18 each.. bought 2 sold 1 cuz i thought this one would last.. not... 700 miles later
went to the vato zone got me a lifetime warrenty reman one thinking about doing the mod before i stick it on.. its a cardone reman i was wondering if i can do the mod to this one??
I just did it recently and it works amazing. My motor barely moved up and I was sure it was fried when before I tried this. It was really moving poorly.
Now it moves about 3-4 second ETs. It is great. As for the safety, I tested it on my hand and it is not going to break anything stronger than pasta. I also did a hell of alot of research before I did this.
Look here for a minute, it has other links inside too.
http://www.fastlsx.com/forums/showthread.php?t=14445
As I said (in the link) the express motor down feature is not corrupted and the motor stops just fine at the stoppers.
Let me know if I can help with anything.
I couldn't just not say anything!
Autotrix does have a guaranteed safe way to do this. I would certainly do them both. The autotrix kit definitely solves the other engineering blunder in the F-bodies.
Just off the top of my head, has anyone considered seeing what voltage your getting at the motors? If there is a drop through the switch or due to skinny wires used in the first place then the lowered voltage will make them slower than they should be. A wiring upgrade or a switch cleaning may be the fix.
https://ls1tech.com/forums/showthrea...light=autotrix
Hotwhip has also compare voltages before and after with similar results.
Thanks!
