Faster Windows?? Upgrade
Old Apr 25, 2006 | 12:34 AM
joesmith136's Avatar
Default Faster Windows?? Upgrade
I am sick and tired of my slow A@# windows!!! I've replaced the motors a few times but I just want them to go up and down quickly like all other cars. Anyone upgraded there motors or have any ideas? I want to do window automation on my alarm and don't want it to take forever for them to go up Thanks.
Old Apr 25, 2006 | 01:52 AM
2MuchRiceMakesMeSick's Avatar
Simmens makes about the best replacement for the window motor
See the FAQ at the top to get detailed instructions on how to replace them.
Old Apr 25, 2006 | 07:32 AM
01Z28M6's Avatar
You can bypass the thermal regulator built into the motor. This will cause your motor to fly but getting around the thermal protection has it's own risks.
http://web.camaross.com/forums/showthread.php?t=443785
Old Apr 25, 2006 | 07:57 PM
WhiteBird00's Avatar
Ungrounded Moderator
My windows started acting up last week. I've heard that the Siemens motors are more reliable but are they faster than stock? I think Advance Auto is the only common place that carries them, isn't it?
Old Apr 25, 2006 | 08:07 PM
JPMuscle's Avatar
You could covert everything to to 16volts, exactly how i dunno but you could prolly search around and find some info.
-john
Old Apr 25, 2006 | 08:12 PM
chaman's Avatar
I installed Siemens recently and the wimdow goes up and down fastly enough. Also they have lifetime warranty through Autozone!
Old Apr 26, 2006 | 04:42 PM
lt1formula2000's Avatar
why can't we just have power window motors like ford's. my friends 91 stang and another buddies 87 F-150 both with original window motors still move twice as fast a my 2 month window motor does in my T/A.
Old Apr 26, 2006 | 11:08 PM
rotwiler's Avatar
My windows have worked great since new, but I always use a silicone lubricant in the triangle piece next to the side mirror and instantly you can see a speed increase. With the Fords, they are pretty fast, but they break all the time too.... on very cold days, 1 time hitting the button and something breaks. Back when I had mid 90's Mustangs, I had the windows fixed under warranty 3 times in 3 years and car had less than 30k miles on it when I traded it in.
Old Apr 27, 2006 | 03:41 PM
My local Advance Auto doesn't have the Siemens motor in stock but they have one by ACI that also comes with a lifetime warranty (it's also $20 cheaper). Anybody ever used one of these or know anything about them?
Old Apr 27, 2006 | 11:28 PM
They didnt seem any faster then when my camaro was new. They are all about the same really but siemens have been the most reliable/cost effective out of all the ones avaliable.
Wow how many miles do you have on your car?
I suppose the reason you created this thread is because of the infamous slow motor in these cars. A siemens will fix it where it is back to the same speed your window was when the car was new.
Old Apr 28, 2006 | 11:17 AM
rotwiler's Avatar
I only have about 40k miles, but the windows are used alot in the summer and at the track(sometimes 20+ times a hour). Anytime I see the windows slow a little or slightly hang I clean the guide and spray some silicone and all is good again. When I first bought the Z28 with 1,500 miles the passenger window would go slower and hang a little, that is when I started using the silicone.
Old Apr 28, 2006 | 02:33 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I like your avatar rotwiler... I love the breed, they are great dogs.
Back on topic, when I insulated my doors, I adjusted the tab that presses against the window and lubricated the gears / sliders with white lithium grease and that has seemed to help a great deal with the speed of the windows.
Old Apr 28, 2006 | 02:50 PM
98silverz28's Avatar
rotwiler....where do you get this silicone at...whats it called...and how do you apply it exactly? does it really show much improvement?
Old Apr 28, 2006 | 09:27 PM
rotwiler's Avatar
When the window goes up and down it slides through the triangle shaped piece on the door, I used a lubricant in the slot and let the window go up and down a few times and put a little more in. When it gets dirty in there, the window catches and slows down or goes up uneven.
Old Apr 28, 2006 | 09:30 PM
rotwiler's Avatar
Thanks, the picture in my Avatar is my 2 1/2 year old female, she is about 160 pounds. I had another female and a male, but they passed away about 1 1/2 years ago from cancer and I think old age(the male was 13).
Old Apr 29, 2006 | 05:37 PM
qwikz28's Avatar
upgrade the big 3!!!!!!
Old Apr 30, 2006 | 10:07 AM
Dom's Avatar
Dom
I'm still confused where to lubricate. You spray it at the triangle piece? I can't what that does. Can you be more specific?
Old Apr 30, 2006 | 10:14 AM
qwikz28's Avatar
in the corner closest to the front of the car. thats where the opening is the tightest on the window and slows it down the most. i havent gotten around to doing that yet but im just wondering if that makes peoples windows greasy and crap? what should we use di-electric grease?
Old Apr 30, 2006 | 12:12 PM
yea, i would also like to know what exactly this lubricant is called, and do you get it at autozone or o'reilleys or what?
Old Apr 30, 2006 | 02:36 PM
UNDER PRESSURE MOD
I just used white lithium grease. It did make a little bit of a difference in the speed at which the windows go up.
