CD skips when I go over bumps
Old Apr 26, 2006 | 11:30 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
Default CD skips when I go over bumps
Well?? I have a Best Buy mount, and a Alpine 9845 or so head unit.
Old Apr 27, 2006 | 12:02 AM
gforce477's Avatar
Get an IPOD and hook it up, those don't skip.
Old Apr 27, 2006 | 12:15 AM
Sgt. Spuds's Avatar
Thats what I do now, I want to be able to listen to cd's as well though.
Old Apr 27, 2006 | 12:21 AM
99camarosupersport's Avatar
sorry to jack, but what ways do you guys hookup your ipods, mine is on some big fugly stick thing that plugs into the cig. lighter. blah. and it plays over the radio, so i'm not getting the quality i should.
Old Apr 27, 2006 | 12:22 AM
00'WS6Rocket's Avatar
get the gm aux-9 and hook it up to your cdchanger port on the back of your radio(stock) and get headphone jack to rca's
Old Apr 27, 2006 | 08:21 AM
Sgt. Spuds's Avatar
^what he said. Then run the RCA to headphone wires under the console to your ash tray, imho the best spot, you can also pull more wire out of the console, and move it over inbetween the Ebrake and the shifter boot, it tucks nicely there, and you can still have the ashtray clossed..
Old Apr 27, 2006 | 08:56 AM
todddchi's Avatar
Well, if it has always been like that, then the back of the radio probably isn't secured properly or maybe the actual head unit had a laser problem from the factory.
If it has just recently started doing it, and it is getting worse, then it's possible the laser is just losing alignment.
How old is the h/u? Did you install it yourself?
Old Apr 28, 2006 | 12:48 AM
nice setup spuds, how hard is it to change songs
Old Apr 28, 2006 | 09:55 PM
Sgt. Spuds's Avatar
Not hard to change songs, if you have memorized your playlist, you don't even need to look.
It got worse after I went off into a ditch. Headunit is pretty new, I installed myself.
