Best way to wire sub amp to monsoon
Old May 1, 2006 | 09:33 PM
pHEnomIC's Avatar
Default Best way to wire sub amp to monsoon
I have a sub amp I would like to wire to my monsoon setup. I got the power, rem, ground all ran. I need to figure out the best way to get an audio input. I know there is more than one way. What do you recommend?
Old May 1, 2006 | 10:35 PM
todddchi's Avatar
Tap into the rear channel amp inputs.
Straight high level signal from the head unit, easy to get to, already ran for you.
Grabbing it at the speakers adds another layer of distortion.
Old May 2, 2006 | 07:16 AM
2MuchRiceMakesMeSick's Avatar
I would use a high to low level converter. PAC makes a decent one
Old May 2, 2006 | 01:17 PM
Koncrete's Avatar
I went with a line output converter on the sail panel speaker, cheap and effective. the speakers in the hatch don't have bass freqencies ran to them (crossed at the amp)
Old May 2, 2006 | 03:12 PM
todddchi's Avatar
Why are people using a line level converter from the rear sail panel speakers as opposed to the amp ins from the h/u? I don't understand it unless you have a sub amp w/o a crossover.
One less layer of distortion tapping off the amp inputs...
Oh and the line level converter is a given if you amp doesn't have high level inputs. If it does, just use them. The head unit sends speaker level signals into the monsoon amp. Not RCA level.
Old May 2, 2006 | 06:08 PM
Koncrete's Avatar
because it's off a monsoon system.... not exactly like your going to get a clean signal from ANYWHERE...
besides it's sub freq. you cannot hear the difference between 1% and 5% distortion...
Old May 3, 2006 | 07:55 PM
Black Plague's Avatar
I found out a pac-01 converter will work and your stock sytem will still work the same and have your subs bump to. http://www.tune-town.com/Cars/stuff/pac_oem1.htm
Old May 3, 2006 | 08:24 PM
todddchi's Avatar
You don't need the pac unit.
If your amp has speaker level inputs you can use it as-is. If it does not you can buy any line level converter and tap it off the amp inputs yourself.
cheaper and easier.
Old May 3, 2006 | 10:20 PM
Well I am going with the PAC-1 converter no line inputs on my eclipse amp and using my Phoenix gold dual amp kit rca's ect! I am trying to get the best quality sound this way! Well as quality as it can get using the stock monsoon deck. Shoulden't be to bad. And for you Monsoon haters
Old May 5, 2006 | 01:12 PM
pHEnomIC's Avatar
Quit hatin the monsoon, it sounds really good in my car and i have a trained ear.
Old May 6, 2006 | 12:04 PM
Koncrete's Avatar
how does one train an ear? did you attend some sort of vo-tech or a college? did you recieve a deploma of some sort or a pedigree?
Old May 6, 2006 | 03:58 PM
pHEnomIC's Avatar
Umm learn your audio stuff, listen to high end home theatre, computer, etc multimedia setups. Basically, I know what sounds good and what doesn't.
Old May 6, 2006 | 05:05 PM
Koncrete's Avatar
ahh, you learn what sounds good to YOUR ear...... gotcha...
it's funny how one person can really like the way something sounds and another will think it's garbage.
I gave up trying to compete sound quality for the simple fact that even the judges (whom all share your trained ear) couldn't agree on what sounded best....
Old May 6, 2006 | 05:48 PM
cws T/A's Avatar
good sounds are when the mirror falls off from the BAAASSSSS
Old May 6, 2006 | 07:50 PM
Koncrete's Avatar
but but but, you can't "hear" those
Old May 7, 2006 | 02:00 AM
todddchi's Avatar
Old May 7, 2006 | 10:15 AM
pHEnomIC's Avatar
Originally Posted by todddchi
I must have some aftermarket stuff in my car then because it truly does sound good. If you guys think it sounds that bad, i really must have something done to it.
Old May 7, 2006 | 11:11 AM
Koncrete's Avatar
