Opinions on a new HU
Stats can be found at this page http://www2.panasonic.com/webapp/wcs...s&displayTab=S
Is 18 watts rms 50wx4 max decent? I'm not very informed when it comes to audio electronics so any input is welcome. Opinions, criticisms, suggestions anything.
You may try it with it plugged into the factory wiring harness, if the bass is dead and it sounds off, you may want to try going directly from the head unit to the speakers with the power wires, having the stock monsoon amp in the middle can sometimes make it sound less than perfect. But I'm pretty confident if you want it to sound real good you will need a sub if you don't have one.
Hope that helps.
Should have mentioned it earlier but I already have a sub in the back. 12 inch 2000 watt powered by an 800 watt amp. With that in mind, do you think that getting a harness to plug the radio straight into the car's harness will produce a good sound?
Worse case scenerio you could swap the bulbs in you car to a different color. If it bothered you that much. I do like the red Ta lights as well though. I just didn't want to get a deck simply to get red lighting. I think a deck decides about 98% on how your system sounds, you can make swap meet speakers sound decent with a good head unit.
Changing the dash lights is not an options. The red looks way better than any blue or green would in my opinion. I had considered ripping apart the HU to change the lighting in that but based on my previous led work that wouldnt be a great idea, plus the lcd would still be blue or whatever color it came in.
*edit* hmm looking at the Clarion stuff, now I'm not even sure if I'd consider ANY clarion units. I looked up the ipod adapter for them and it states that you cant browse the ipod by artist/album names. It only recognizes 5 playlists which it renames. Treats them as 6 cd's in a changer. First "cd" will play through all of the songs you have in the order that they were burned onto the ipod. and the other 5 "cds" are your first 5 playlists on the ipod. Kinda lame. I honestly didnt think shopping for a stereo head unit would be this tough.
