Component & Coaxial Question
If I do that how will the sound be from the rear. I've never had any tweeter sound comming from behind me and unsure if I would like it? Any opinions?
Thanx
Can those tweeters be removed from the coaxial?
I've got tweets in the A-pillars as well and they work great in that location.
To be honest, you may be able to leave the jumper off of the tweeter level adjustment pins and not power the tweeter at all if you dont like it. That is just a guess though...I will be getting my xr650 csi/cxi set next month sometime
What if I put a set of JL component speakers in the back and moved thier tweeter and crossover to the front. Put the tweeters in the a pillar still and then mount the coaxial speakers in the doors. Overkill on the tweets up front?
That would leave just midbass in the rear and I think I could fit both crossovers under the kick panels...maybe?
as far as mounting the tweeters, i just mounted them by the window controls simply coz i didnt feel like tryin to make them fit in the a-pillar anywhere, not to mention the instructions that came with them suggested they dont be placed more than 8" away from the woofers for "maximum" sound quality...dunno if thats true or not, but whatever.
system sounds great now, just need to get clean power to them to make it sound better.
Anyone else have any opinions?
oh yea, the crossovers will fit behind ur kickpanels.. just every time u wanna change ur jumpers, realize u gotta take that whole panel piece/door sill out to get to 'em
but yea, they will fit snugly behind the plastic bracket - ur kick panels will stick out a wee bit tho, but it really aint that noticeable.have fun running the wires thru the rubber hose that runs from the door to the car itself - my fingers hurt for a while tryin to push the wires all the way thru that hose
A bigger amp that can deliver a lot more power into a 4ohm speaker is going to give you a lot more volume before it starts to distort and the speaker will last longer and sound better.
As for the tweeters, that 8" thing is a very generalized guide. Let me explain. Due to the way humans percieve sound (having a left ear and a right ear) our brains are very sensitive to the left right differences between two sound sources. Since we want the tweeter to blend in perfectly with the mid for a seamless sound you need to keep them lined up vertically as much as possible. Although we can tell left and right sounds apart very easily we have a hard time determining how high up or low down a sound is coming from. We are not good at that. So you can mount a tweeter much higher than 8 inches so long as it is very close to the same vertical plane as the mid.
If you think about most home speakers you always see the tweet above the mid and not next to it. Competition vehicles often mount mids in the kickpanels and tweets in the A-pillar and the sound can be amazing and realistic, why, becuase they are lined up vertically.
Back to Camarokidd24, if you know you like rear fill then definately go with it. That's why I asked. There's no point in being disatisfied. I would recommend mounting your coaxes in the back and get a nice component set for the front. If the coax x-over has seperate wires for the tweet then you can simply unhook them to turn off the tweeter, but I would try and lower their output first. Pretty simple decision to me.
On word of advice. I would run new wires, 4 pair, to the fronts from the rear and use them to wire up your front stage. Mount the x-overs in the back by the amp. Use some good wire of 12 or 14 guage at least. Then you don't have to worry about loses from the factory wires. Plus you have peace of mind.
so i shuld still hear little-to-no distortion when i get my 4-channel amp from jl audio, correct? since i wont have to push the volume up as loud. question is, why am i only hearing the distortion at mid-range levels? why wuldnt i hear them when the bass/low-levels of a song hit, since i only have the tweeter as a separate component, whereas the woofer/mid is the same cone? the bass hits beautifully...almost turns me on. but sometimes, when i listen to country, it just sounds like its mid-range levels that distort. any help on that?
Now assuming that the speaker is working as it should, you may want to verify it's playing within it's limits. It has a passive x-over that will roll it off at the upper registers to let the tweet come into play, but almost no passives x-overs will limit the low freq bass going to that mid. If you didn't add some type of choke to the mid it may be trying to play notes below it's usefull range. A lot of aftermarket amps will have a high pass filter built in and typically you would set it for around 90-120hz to protect the mid. That could be your problem right there.
Another possible reason you are hearing those problems could be due to a resonance in the door. Something my be vibrating at a harmonic (multiple of a fundamental tone) of a lower note. For instance, think of how a big subwoofer can play in a car and certain plastic panels will vibrate and give off a much higher freq than the original bass note. Sometimes people can confuse this resonance with a distortion coming from the subwoofer. In your case the mid may be trying to play too low a freq and it's causing the door panel, speaker grill, lock rod or something in the door to vibrate and sound like speaker distortion. Since we are more sensitive to the upper mid range of freqs this is what we are most likely to hear. Not the orignal bass note causing it.
So if you have the lows being filtered out of the mids and you know there's nothing around the speaker or the door panel vibrating, then you may have another problem.
Let me ask, does the level of distortion go up with the volume?
Is it only on one side of the car?
See if you can isolate it by unplugging all other speakers including the front tweets and rear coaxs and opposite side mid. Is it still there?
If so you may have to put your ear up aginst the door to see if the distortion is really coming from the speaker. Like I said earlier, it may be coming from next to it. You may have to pull the door panel off and put your ear up close and listen to the whole panel while you play that country music.
If it is for sure the speaker, pull it out and move the suspension in and out in a quiet room. Listen and feel for any scraping. Sometimes a speaker will get it's voicecoils out of alignment and they will scrape against the pole piece or front plate. I've even seen the windings become unglued and get tangled up and not let the cone move smoothly. That will show up as a upper mid range distortion.
Ideally your problem is something that needs to be investigated first hand. It's hard to diagnose over a computer, but hopefully I gave you enough stuff to check that you will find the problem.
Jason
I am definatly running new wires for the install and taking all the old stuff out. I think I know what I am going to do now. I will put a set of JL XR650 compontents up front, midbass in the doors and tweeters in the a pillar. Put my JL XR650 coaxials in the sails and tune the rear tweeters down or off accourding to my sound preference when I get them installed.
I never thought of putting the crossovers in the back. I am tucking the amps in the passenger side cubby and there will be plenty of room left (I hope). I was planning on putting the front crossovers behind the kick panels and dropping the rear fill down into the sail panel cavity. This would save a lot of wire but not allow for easy tunning. Damn, once I think I'm alset I get into something else...
loli know its only the front left woofer that distorts, just by tuning out the highs and cuttin off the rest of the speakers. the distortion doesnt necessarily get louder with an increased volume..i guess it just gets more...noticeable? i know when i blew the **** outta my stock speaker, the tweeter cone was halfway ripped off the woofer. every time i turned the music up louder, the distortion got louder. but thats not the case with this speaker. im gonna order my new amp/amp rack an hook it up to see wut it sounds like afterwards, an probably end up tweakin the hpf to about 90hz, like u suggested...just hopefully my speaker aint completely blown by then.
once again, thanks for the info...really did help out alot!
camaroguy_02, after all that typing I still forgot to mention something. In order to help find that distortion your hearing, instead of using music, try using test tones. If you don't have a CD for that purpose then go to Realm of Excursion / Downloads and download all the sine waves from about 20 to 123hz and burn them to a CD. You may hear the distortion at those frequencies or it may be higher up. Also try these sweeps: 20Hz to 250Hz sweep, 25Hz to 600Hz sweep, 35Hz to 1KHz sweep and 20Hz to 20KHz sweep. Basically you want a realiable way to create the distortion your hearing so that you can better pinpoint the source. Someone turned me on to this site just recently, their test tones are pretty good although they don't go higher than 123Hz.
http://realmofexcursion.com/
If you can narrow the problem to a particular freq you can play it over and over while you move your ear around and also press on the door parts to find the source.
Oh, and the same basic process can be used to find rattles from your sub as well. Certain freqs will cause interior panels to resonate/vibrate. Just play the particular tone on a loop while you try and find the offending panel. If 2 panels are rattling against each other, apply some adhesive backed felt between them. If it's a big panel by itself, try stuffing some foam padding behind it. Just don't play the pure tones for too long at too high a level as you'll be heating up the voicecoils more than regular music would.
Here is another source for test tones , their lower freqs are not very good, but higher ones are OK.
20Hz
30Hz
40Hz
50Hz
60Hz
70Hz
80Hz
90Hz
100Hz
125Hz
150Hz
175Hz
200Hz
225Hz
250Hz
275Hz
300Hz
350Hz
500Hz
600Hz
800Hz
1000Hz
1200Hz
1600Hz
2000Hz
2200Hz
2500Hz
3200Hz
4000Hz
5000Hz
6000Hz
8000Hz
10000Hz
12000Hz
14000Hz
16000Hz
18000Hz
20000Hz
Brown noise
Pink noise
White noise
http://www.mp3car.com/vbulletin/showthread.php?t=63949
