Autometer Hook Up! Help Please!
Old May 10, 2006 | 11:02 AM
BlackBirdWs6Zzz's Avatar
Default Autometer Hook Up! Help Please!
Ok I have a 5" tach. I need to know where you guys hooked up the power and where you hooked up the ground. I have a LT1, which wire to I tap in for the RPM's.
I need to know a 12v power source that isn't on 24/7, just something that comes on with the ignition or light switch!
NEED RECOMMENDATIONS QUICKLY THANKS
!Josh
ANY PICTURES OR WRITE UPS WOULD BE GREAT! MAYBE EVEN A SCAN OF THE DIRECTIONS TO HOOK UP! I bought it used!
Old May 11, 2006 | 12:17 PM
Ok sooooooo...........Some guy who had an LT1 told me it's the white wire under the passenger kick panel.........here is what happened.
so I tried to tap the RPM wire, which you said was white, but I did it and it didn't work, then I realized as I was connecting it off and on, my interior lights were going off and on. hahaha. so I was like hey i'll try to white one with the black strip. (WRONG) Then my security light came on and wouldn't let me start my car, I locked the doors, alarm set, then I opened the doors, teh alarm went off (usually i turn it off by putting the key it and putting it on the ON position, but that didnt work. It went for about 3 mintues and shut off, then it let me start it again (PHEW)
So i have determined it's not the white or white with the black stripe. Any other suggestions...I scared now to just tap wires now.
