Satellite radio mounting
My antenna is on the back hatch glass, pretty unobtrusive, I don't even notice it anymore
The reciever is in front of the shifter on the TCS switch panel
http://members.***.net/drwho4/P4193022.JPG
Link cause the pics pretty big
Copy & Paste Moderator
I've got a Roady XT and have the antenna mag mounted between the hatch opening and the stock antenna so it somewhat blends in. The unit itself is mounted inside the center console. I added another hidden lighter plug inside the front of the console and tapped into the wires for the factory plug. I'm using the FM modulator of the XT. It works but the factory Monsoon sucks so I may replace it before long.
Originally Posted by Toasty
I routed my antenna up to my rearview mirror, and it sits nicely on top of that. Nice view of the full sky.
Okay, i duno about you guys ,.. but i have sirius sat.. and my antenna right now sits right over the hatch window up between the t bar.. I have tried putting the damn thing everywhere !! i get sooooo shitty reception,.. you guys that are hiding your antennas.. you still get good service !!??
1 Post
2K2WS6TA, that is EXACTLY what I thought of when I read the title. Easy to access and read, not likely to get bumped or anything. . .and close to the head unit!
Lethal, that is almost what I pictured. On the roofpanel right there in the center, just above the glass.
Duff
Duff
my antenna is mounted in the engine bay on top of the passenger shock tower
works almost flawlessly, if i didn't coil my extra wire poorly it'd have a much better signal.
Ungrounded Moderator
my antenna sits on top of my rear view mirror, and I get perfect reception.
My radio is mounted on a block of wood that I slide into the cubby hole beside the cig lighter, and I have the wires running inside the center console up through the back of the hole .. that way I can remove it when I want/need to.
Originally Posted by KilerTA
Ive had the same ? also ive heard about people putting there antena inside there spoiler on the trans am will this work?
it will work as long as you do not have metallic paint.
