Factory alarm acting up...part 2
Hey all, when I lock my doors either with the fob or door switch, close the door (when already closed too) the alarm goes off. As soon as I hit the panic button it stops and is fine. I found that the aftermarket deck is wired incorrectly, when I turn on the headlights via the switch, the deck powers up. Also, I checked the BDM for DTCs and the only current one was a 24 (as well as a history 34) which translates to: Fasten Seatbelt Indicator Lamp (Circuit Shorted to Ground or Battery +). Has anyone run into a situation like this before? I'm assuming that 24 means I have a shorted wire somewhere? Any help would be greatly appreciated. Thanks.
mine just started acting up last night at 3 am...everytime i lock it the alarm goes off ten seconds later. what the hell...it beeps twice then stops...ten senconds goes bye and it does it agian
mine started to do the same. I screwed with it trying to find the problem then just decided to do the silly GM programing to dissable the alarm and set it up as a keyless entry only.
mine does the whole 10 seconds later stuff. i just unplugs the shock sensor in the back where the spare is and it stoped. with the shock sensor plugged up its beeps twice every 10 seconds... any one else having this issue
