tach signal
Old May 29, 2006 | 05:54 PM
darbydarby's Avatar
Default tach signal
trying to put a tach w/shift light in my 98 camaro,tapped into white #35 pin wire on pcm and cannot get any signal,tried cutting the wires and getting a better connection still a no go.
any ideas on what i should try?
Old May 29, 2006 | 07:46 PM
Christian8A's Avatar
This might help you
Bad tach or bad connection
http://www.myls1.com
http://www.newmusicstage.com
Old May 30, 2006 | 04:19 PM
flash12t's Avatar
stupid question but did u tap into the top pcm or the bottom . . ive done that before. .
Old May 30, 2006 | 04:24 PM
darbydarby's Avatar
~~~~~~~top~~~~~
Old May 31, 2006 | 11:59 PM
darbydarby's Avatar
ok so...we hooked it up to an old truck to see if the tach was just bad,it worked just fine.
so were tapping into the #35 white wire,but somehow not getting a signal.this is frusterating.
Old Jun 1, 2006 | 03:31 AM
Sorry to hear that man, but I installed mine and forgot to clip those wires in the back of the tach, but then it worked fine.. mine is a 2001 Z28 I think is a different pin, I used the #10(white) of the top side of the PCM (white) but I heard in a 98 was a #35
