Pac Swi-alp
Old Jun 3, 2006 | 05:39 PM
mdsmooth's Avatar
Default Pac Swi-alp
Hi guys. I just purchased the Alpine 9857 and installed it with no problems. I am having trouble with the PAC unit I purchased. I can get the unit into program mode, but once I start programming the buttons on my steering wheel, nothing happens. Has anyone gotten this to work successfully? The directions are confusing as it is. I think I have it wired up correct, or else it wouldn't go into program mode. I have a 2000 Z28 with the monsoon system. Thanks!
Old Jun 3, 2006 | 05:55 PM
presto_z's Avatar
are you hitting the designated button on the factory remote then holding the steering wheel control for 10 sec....i was having problems where only the first function would work, and it was always sending the signal, i wasnt holding it down long enough...look in the trouble shooting section
Old Jun 3, 2006 | 06:09 PM
mdsmooth's Avatar
I didn't know I had to. The receiver only came with a wireless remote. But a wired remote was optional, so the PAC unit should still work.
Old Jun 3, 2006 | 06:15 PM
presto_z's Avatar
yeah, the pac unit learns the signal from the aftermarket stereo remote, after you hit the program button on the pac you aim the remote at the sensor on the pac unit(be within a few inches), then press and hold the corrosponding button on the steeringwheel for atleast 10 seconds, i held mine for about 15 just to be sure..(this is all off memory, ill try and find all the paper wrk to refresh my memory)
Old Jun 3, 2006 | 06:26 PM
mdsmooth's Avatar
Makes sense. The instructions said nothing about using the remote, but I knew I was missing something. Let me know what you find. Thanks.
Old Jun 3, 2006 | 06:29 PM
presto_z's Avatar
i looked and i must have thrown it away(i usually save all that stuff) if u go to the pac wbsite im sure that they can help ya out
Old Jun 3, 2006 | 07:38 PM
mdsmooth's Avatar
So when you aim the remote at the PAC sensor, do you have to hold down the remote button and steering wheel button to program? For example, the volume up button on the remote and the volume up on the steering wheel. Hope that's not too confusing.
Old Jun 3, 2006 | 10:52 PM
presto_z's Avatar
ok you first aim the remote at the pac sensor just push it once, the light should flash...then press and hold the button on the steering wheel that you want to do that action....
Old Jun 12, 2006 | 09:55 AM
FBDYLVR's Avatar
If you bought the SWI-ALP it should directly hook into the Alpine
the SWI-X has the sensor where you actually program the module and it emits the same remote commands to the head unit.
Old Jun 12, 2006 | 01:01 PM
imnotplutonium's Avatar
^^ thats what I thought too
Old Jun 12, 2006 | 01:30 PM
presto_z's Avatar
^^^^i think he is correct....sorry for any wrong info....but if u need help w/ swi-x ill be more then happy to help
