98 SS Monsoon How many Watts 250 or 500?
I thought all monsoon stereo's were 500 watt but i read on here that the early ones were 250 watt. What should my 98 SS have if it has monsoon? Thanks Brandon.
The ratings are definitely not RMS. The 500 watt figure is in best case a total addition of the peaks of each of the 4 head unit channels and the 8 amplifier channels.
Don't get tied up on it - it doesn't matter, and there isn't a "drop in" factory amp upgrade which is the main reason this question tends to come up.
If you want better sound replace the front door speakers and head unit. The amp is not the weak point.
GM marketed the Monsoon stereo system in the '97 to '00 Camaro's as 200W. I believe this was solely to distinguish it from the 500W Monsoon system available in the more expensive Pontiac Firebird. The '01 and '02 Camaro models were listed as 500W.
Even if we concede that the 500W rating is dubious "ILS" spec, it does not make sense that GM would arbitrarily market the same part at such widely different rating values. I'm not saying that GM would be so wasteful as to produce 2 completely different amplifiers, but it is likely the 200W Camaro amplifier had the gain severely reduced. Hence, the significantly lower power rating.
Since the 200W amp and 500W amp are pin compatable with each other, it makes sense that GM would have only one replacement part number (500W) for both amplifiers.
Replacing the 200W amp with the 500W may make a difference in how loud the overall system will play. But I would not expect any improvement in sound quality.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Ungrounded Moderator
Not only is the replacement part number the same for 98-02, the part number stamped on the amp itself is the same through those years.
Originally Posted by ls1wfo
Just gimme a 100 watts RMS with 4 channels and .02 THD AND I'd be really really satisfied rockers .
Originally Posted by wickedwarlock
I belive all 3 are weak. But that's just me and probably mike@fbodyaudio. ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
People doing a simple head unit / 4 speaker install are better off using the monsoon amp than they are just using the head unit amp, or going out and buying some junky pyramid amp to use. The point is missed because there are not many people in this situation, but on a tight budget it can work pretty well.
