HOw do you....
If, on the other hand, you just want to make sure that nobody can use it to open your car then you actually have to reprogram your other remotes and leave the one out so that it no longer matches. Any remote that doesn't get reprogrammed at the same time as the others won't work with your car anymore.
I know I am going to repeat what is already posted but maybe I can say it alittle different!
Once the door is closed turn the key on and off 3 times and on the 3rd time leave key on the on postion (if you mess up turn key off and open door and start over) Once you do that like said before the doors will lock unlock and the hatch will pop then with key still on hold down the lock and unlock bottons at the same time until it locks unlocks and pops the hatch again! I have done this on a 99,00 and a 02 and it worked everytime.
