T-Tops
Old Jun 13, 2006 | 12:06 PM
DZBIRD's Avatar
Lightbulb T-Tops (Stereo Related)
Has anyone more there t-top holder ??? I want to put some subs in my trunk area but still be able to use something to secure my t-tops down.........any suggestions???
Old Jun 13, 2006 | 12:10 PM
DZBIRD's Avatar
Has anyone "MOVED" there t-top holder........not more
Old Jun 13, 2006 | 12:17 PM
CamaroSS615's Avatar
I had to remove my t-top holders on my 98, in order to get the enclouser in that location. I ended up having to use the backseat to store the tops when I had them out. You can look into getting a stealth box for your F-body, and this will keep you from having to remove the t-top holders. I know some of the guys here use the stealth enclouser, but I have never used this type of enclouser.
Old Jun 13, 2006 | 12:22 PM
WS-Six02's Avatar
i built a box with a 10" l5 that fit down in the trunk with the holder still mounted and just made the box easy to remove, mounted the amp and crossover on the box so all i have to do is disconnect the rca, power and ground and yank it out other than that i just put my t-tops in my back seat.
Old Jun 13, 2006 | 12:28 PM
FrozenMonkey's Avatar
Better yet, keep your holder in the same spot and put in a badass custom box and amp rack like mine:
Old Jun 13, 2006 | 12:31 PM
WS-Six02's Avatar
damn dude thats pretty badass you do that yourself? that speaker box isnt fiberglass is it
Old Jun 13, 2006 | 01:03 PM
up2nuthingud's Avatar
check out JL audio, they have a prebuilt box that fits in the driver side just like that and sounds great with a decent amp.
Old Jun 13, 2006 | 01:48 PM
daryl2cb@yahoo.com's Avatar
Same set up I have. I think that is all the power that car needs with the truck. Believe me and I used to have a 4 runner with 4 12's and two punch 1000's. need less to say the little single 10 is all I like any more.
Old Jun 13, 2006 | 01:59 PM
imnotplutonium's Avatar
yea I got tired of not being able to hold the tops, so i changed out the 2 10"s for 1 10" and used the stealth box. love it. resonates really well and the sound sounds great
Old Jun 14, 2006 | 12:10 AM
I didnt do it myself but I cant tell you what company made the sub box. I know that the amp rack is custom though by the last owner. I hate that sub but it does fine until I can justify spending money on a better one when I barely have the music up. (exhaust is my music )
One sub is definately all you need unless you want to have insane bass that drowns any sort of sound quality. The hatchback does wonders for amplifying the bass. Just get a good amp and sub, upgrade your alternator and you'll be able to thump when ya want but still keep great sound quality. Provided you have decent mid and high speakers that is.
Old Jun 14, 2006 | 04:26 AM
1sick'98WS6's Avatar
i made my own steath box
Old Jun 14, 2006 | 11:26 AM
sgt0704's Avatar
subthump has a box where you can still put your t tops in the hatch, and holds 2 10's or 12's. but you don't use your stock t top holders.
Old Jun 14, 2006 | 11:32 AM
mikerulzu's Avatar
Use two tens in a small sealed box and put them right behind the back seats. I got a jeep box and it fits perfectly.
Old Jun 14, 2006 | 11:38 AM
Have any pics.? I would like to see your setup.
Old Jun 14, 2006 | 12:07 PM
DZBIRD's Avatar
I like your set-up but I want at least two ten inch subs........
Old Jun 14, 2006 | 12:10 PM
DZBIRD's Avatar
mikerulzu
how does it sound.....I like to have loud subs
Old Jun 14, 2006 | 12:40 PM
If you want loud, go with the enclouser that fits in your rear trunk space, with the subs firing off the hatch. I had 2 12's set up like this and they were beating like 4 12's. Only disadvantage of using an enclouser like this, is that you may have to remove your t-top holders in oreder for the box to fit properly.
Old Jun 14, 2006 | 05:57 PM
KEE AUDIO's Avatar
Try one stealth box and see what you think. They put out nice sound but I wanted more!! This is what I did and I still can use T-top holders!!
Old Jun 14, 2006 | 06:55 PM
tbird31's Avatar
dude your setup is awesome! did you cut out the side of the back panel where the spare goes? that's wicked!
Old Jun 14, 2006 | 08:19 PM
you could have a custom shop build a 10 on each side , but you would lose your spare. imo, you should try to find someone with this box and listen to it. i had it in a 95 z28 i used to have and it hit 141 db with a 500 watt phoenix gold amp.
