Alpine DVD Bypass
Old Jun 26, 2006 | 04:23 PM
ChicagoTransAm's Avatar
Default Alpine DVD Bypass
Came across this thread while searching...
https://ls1tech.com/forums/wiring-stereo-electronics/455421-alpine-dvd-bypass.html
HMM....locked for "illegal activities"? Sorry, but was looking for the wiring for the brake switch. Needed to know the color for the brake switch power and everything's been deleted.
Sorry, but THAT is retarded. It's not "illegal" to disable this. Yes, it's illegal to drive with it on, but we aren't talking about a selling dope here. Hell, maybe we should start deleting all threads that have to do with putting in LT headers and ORY pipes since THAT'S illegal. Find it funny, we can talk about how to program out codes so it won't show up at the EPA...but not a ******* stereo.
Sorry...had to vent
Old Jun 26, 2006 | 04:30 PM
jimmy 2 Times's Avatar
i know how to do it, get a switch and a button.
it needs to see 12+ and negative in a sequece.........almost more trouble than its worth.
btw, like said in the original, there are enough bad drivers out there.....
Old Jun 26, 2006 | 04:33 PM
Understand what it needs to see.... but which wire coming from the pedal switch is a switched positive?
Honestly, don't care to watch movies while I am driving.... but don't want to have to put the parking brake on while adjusting settings either. The other thing is, some people may be looking to do this in order to have TVs in back on (which is not possible with this "security")....and be listening to music up front...
Old Jun 26, 2006 | 05:39 PM
2001FireBird's Avatar
Pm'ed ya.
Old Jun 27, 2006 | 02:54 PM
Thanks. Just out of curiosity...where'd you mount your "brain" box? Mine's sitting half under the pass seat in back...but curious if you found a better way.
BTW...your PM box is FULL
Old Jun 28, 2006 | 03:15 AM
WS6nJAX's Avatar
Restricted User
i put mine behind the spare. i did a mod to the factory amp bracket and mounted it to that.
Old Jun 28, 2006 | 10:15 AM
XxXTransAmXxX's Avatar
Just ground it to the head unit's ground, it needs to show ground inorder for it to work....
As I did with my Clarion VRX935VD and it works perfectly now...
As for the wire go here, and see if this helps you www.the12volt.com
Old Jun 28, 2006 | 11:19 AM
its not that easy anymore. You can't just ground them out. They have to be in sequences
Old Jun 28, 2006 | 11:34 AM
It's not? Maybe from unit to unit, but mine is working perfectly.....
Old Jun 28, 2006 | 12:27 PM
Ehrrr...how'd you do that? The cables are only about 3' long
Old Jun 28, 2006 | 01:02 PM
WS6nJAX's Avatar
Restricted User
i have the iva-d310 and my cable was about 8' long. it was tight but it worked.
Old Jun 28, 2006 | 01:16 PM
WS6nJAX's Avatar
Restricted User
and i used a toggle switch and a ground wire on mine to by-pass the park and watch thing and it works fine. i just push down my foot brake, flip the toggle up then back down, release the foot brake and it work fine. i wired the yellow and blue wire to the brake light in the rear. the yellow and black wire i ran back up to the front to a toggle switch i mounted next to my tcs switch. from the toggle switch i simply went to a ground point under the center console.
Old Jun 28, 2006 | 02:44 PM
I mounted mine underneath the seat. it was a bitch to get done cuase everything needed to be fitted nicely, but it worked out. None of the wires will grind in the rails, i don't lose the ability to adjust my seat, and its pretty sneaky way to hide the brain. I wrapped the wires in electrical tape to insure the rails dont chew away at the wires.
Old Jun 28, 2006 | 09:22 PM
presto_z's Avatar
i had to use 2 toggle switches and i had the brain under the drivers side seat but moved because wires got caught up in the power seat tracs and blew a fuse so now brain is just floatin around in back (temp.) and the cd changer is under the passengers seat (so i can acess on the move... in my old camaro i made a custom sub box and box for amps x-box power cap cd changer brain and power converter...it was a pain to get out and pop the hatch to change the cd's) so i 86ed the subs and other jazz ( i listen to zero rap and the stock amp w/ after market speakers is plenty for shadowsfall slipknot and other kickass bands)
