How to find battery drain?
Any help would be appreciated.
Thanks in advance,
Brian
Depending upon what the drain value is other people might be able to point you in the right direction.
You might also find that you have no steady drain, which will again re-focus your efforts.
i'm trying to track down the same thing. When i disconnect my battery and hook up my ammeter in line, it starts out at 1.9 amps, then eventually settles down to 95-105 milliamps. are these numbers normal?
I'm asking because i've killed my battery a few times and i think its crapping out. I just want to make sure its not going to happen again before i invest in the optima.
Here are a few pointers. You need to make sure the BCM and car is not active for about 30 minutes so...
1. Make sure all doors, hatch, etc. are closed.
2. Use a jumper between the negative post and ground point on the passengerside.
3. Hook up your meter using clamps or some method where you can move back and forth.
4. Unhook the jumper.
After doing this if you're reading over 50 or 60 ma's you have an issue somewhere.
You now begin pulling fuses, you can start inside then work your way outside.
When you first open the door you are going to activate the bcm so the ma will jump up for awhile but then should go down. Now I have an aftermarket alarm so you're case may be different but my amerage stayed up due to the alarm watching the door. If you have stock or other alarm it may not do this. keep an eye on the numbers, write them down if need be and keep that in mind.
Now you can go 1 of 2 ways. You can pull all the fuses in the fusebox (as long as you're diagram on the cover is not missing), see what the reading is, then start replacing them, or you can pull and replace 1 at a time.
If this still doesn't show you the problem do the same with the engine bay fuses.
Keep in mind what kind of electrical modifications you have done. If after all fuses have been pulled and the ma's have not dropped you could have a short in the alternator. Unhook the power to the alternator. (MAKE SURE YOU DISCONNECT POWER WHEN DOING THIS!, don't ask me how I know.)
Repeat original procedure after alternator is unhooked.
It's a pain in the *** and can be time consuming. Good luck.
on number 2 below,do i disconnect the ground off the battery and then make a wire from the battery post to a ground?
number 3 below,where do you hook up the meter? do you hook it up on the negative terminal and the ground then disconnect the jumper?
No jumper wire is needed or even useful. Simply disconnect the negative battery cable from the battery and connect your multimeter between the cable end and the battery terminal (positive probe on the cable and negative probe on the battery). Set the meter to DC Amps and read the current draw on the battery (you may need to try different scales on your meter to get a reading). Then start removing fuses until you see an unexpected drop in current draw. The drain is on the circuit protected by that fuse.
the bigger the load the brighter the test lamp
Or you can unhook both battery leads and use a 9v buzzer hooked between them
The tone will change or drop off completely when youve found the short/drain circuit by pulling fuses.
I like this best as I dont have to take my eyes off anything to monitor a meter or a test light.
You cant do this if you have a large cap for stereo.
