New amp issues
Old Jul 24, 2006 | 12:59 PM
qwikz28's Avatar
Default New amp issues
i just replaced an old 4channel Alpine amp which i had bridged into 2channels with a 4 channel JBL amp which i am currently only using two of the 4 channels. the amp swap was as simple as unhooking the old amp and putting the new wires onto the new amp. the only problem is the new amp has a whine to it. the whine does not increase in volume when i rev up the motor but stays constant and eventually gets droned out by the music. the problem is that its very annoying. granted its a more powerful amp, should i be searching for a better ground? the power wires for the 4 channel and the subwoofer amp are both fed off the cap. any suggestions?
Old Jul 24, 2006 | 01:39 PM
Duffster's Avatar
Is it a feedback issue? Gain too high or something?
Duff
Old Jul 24, 2006 | 03:00 PM
ded71's Avatar
Whine is usually caused by one of two things. A bad ground or running your power wires next to your RCAs. I would check those first, and if that's not the case move on from there.
Old Jul 24, 2006 | 03:26 PM
qwikz28's Avatar
Duff
Duff- right when you posted this i remembered that i advanced my gains all the way up after tuning it. i forgot why i did it, but i did. i completely forgot and i just ran to my car and changed it and it sounds like heaven. i appreciate the help and the reminder of my stupidity
Jacob
Old Jul 24, 2006 | 05:27 PM
Duffster's Avatar
No problemo!
