Unlocking monsoon after battery swap
Old 07-31-2006, 09:49 AM
FH212's Avatar
Default Unlocking monsoon after battery swap
I dont have the code I bought the car used.Is there any way to do it without taking it to the dealer?
Old 07-31-2006, 12:24 PM
shouldaboughttheZ's Avatar
Here was the procedure. Don't know if there is a step or something missing when you call it in.
Theftloc Bypass
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed
2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 06010, press the “button” and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Old 07-31-2006, 01:12 PM
FH212's Avatar
I have a question,in step 4 it says press the "button" what exactly is that button.And is that on the radio or on the phone?Thanks.
Old 07-31-2006, 02:18 PM
I think the phone will tell you which button to press
Old 07-31-2006, 03:11 PM
FH212's Avatar
Oh.Ill try Thanks!
Quick Reply: Unlocking monsoon after battery swap
