how to unlock factory radio?
!Dial-up Director
Ther is a certain procedure you must follow, but I forgot it. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> You can go to the dealership and have them remove it so it will not ever lock up again.
Justin
Justin
i got the info i needed from that other board.. thanks anyway
Theftloc Bypass
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed
2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 202107, press the “button” and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Theftloc Bypass
