speaker cover removal question
Old Jun 25, 2002 | 04:42 PM
LS1PoweredZ28's Avatar
Default speaker cover removal question
I was trying to remove the speaker from the passenger side door. I can get the sides to pop out, but the top and bottom will not come out, I feel like I'm going to break something. So is there a trick to getting it off?
thanks,
Kevin
Old Jun 25, 2002 | 06:01 PM
LIL SS's Avatar
Moderator
Default Re: speaker cover removal question
I pulled the door pannels. I don't think you can get to all the mounting screws with out removing them..
Old Jun 25, 2002 | 06:10 PM
ok, how hard is that and how do i go about removing them, also do i need any special tools?
thanks for the responce
Old Jun 25, 2002 | 11:28 PM
Kevin's Avatar
The top and bottom of the cover are plastic melted to the door panel. Some people have been able to break them free but most have cracked the cover. Removing the panel is the correct way.
Kevin
Old Jun 26, 2002 | 12:01 AM
ls1mn6's Avatar
ditto, I broke a cover before I figured it out. Besides, the speaker is not exactly behind the grill!
Old Jun 26, 2002 | 04:27 PM
thanks a lot guys.
Kevin
Old Jun 27, 2002 | 12:18 AM
LIL SS's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1PoweredZ28:
<strong>ok, how hard is that and how do i go about removing them, also do i need any special tools?
thanks for the responce</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You need a phillip screw driver and that is it.. If memory serves you have 3 scews to take out, then the DP lifts up and out. Make sure you lift up before you pull out. The panel sort of hangs on the door that way..
Old Jun 28, 2002 | 03:46 PM
how do you get the door panel around the door handle and door lock?
Old Jun 28, 2002 | 06:22 PM
LIL SS's Avatar
Moderator
<strong>how do you get the door panel around the door handle and door lock?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I didn't take mine all the way off. I rotated the front up and the back down. This gave me enough room to get the speakers out. You can also move it around enough like that to dynamat..
Old Jun 28, 2002 | 08:37 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> I didn't take mine all the way off. I rotated the front up and the back down. This gave me enough room to get the speakers out. You can also move it around enough like that to dynamat..
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thats what I did too, I just didn't think that it would be good for the door handle or the locking mechanism.
Kevin
