headlight/electrical problem
MAIN PROBLEM...... alright my headlights flip up when they shouldn't and go right back down and the left sides motor keeps running like it is still trying to shut it....
SYMPTOMS...... Pulling out of drive way this morning i fliped the lights to on, ment to go to fog lights, turned them off so the lights would go down and started making funny noise.... well played around for a few minutes and learned that when i turned on just my fog lights my headlights would flip up and go right back down and make a funny sound, left side, for about 3-6 seconds.... Ok got to school about a 1 hour drive got out pressed the keyless lock button and headlights flipped up and back down and there was the sound. ok went in, few hours later came out unlooked car with keyless remote and headlights flipped up and down and made the sound. ok thought it had something to do with foglights turned the foglights off, the switch under the light switch, and problem was still there......
Ideas would be helpful here.
EDIT::::: one other thing, if i have the door open and push the inside look button the same thing happens as with the keyless..
Car is a 99 WS6
<strong>Allright, this may be sort of long but im trying to be as descriptive as possible.
Car is a 99 WS6</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The plastic gear inside your headlight motor is stripped. You can do one of 3 things: 1) go to the dealer, if under warranty and have them replace the motor. It will solve all the wierd problems your having.
2) If not in warranty, pay for it yourself.
3) There's a procedure, which I have successfully done that allows you to fix it for free. Its not that hard. See, the plastic gear has teeth all the way around. But only half of them are used, the other side never gets touched. You flip the plastic gear, put it back in and your done. STOP using your lights now if you want to try this because the more you let it grind for 3-6 seconds, the more teeth you will chew up.
Go here for complete instructions, scroll all the way to the bottom and do the last set of instructions. You can even buy a metal replacement gear from this guy if you want. If you buy it then do those instructions.
http://www.bfranker.badz28.com/headlightfix/
Good luck.
Get the metal gears if you have the money, your headlight motors should last forever.
<strong>any more ideas??? or has someone had these problems before, oh yeah i was wrong about the key in the ignition, i tried that again and it didn't pop up and go back down.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Did you try the gear flip?
Thats what the problem is.
K-man
<strong>Is it me or is everybody getting sick of GM's ability to make a pop-up headlight that works??? <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Its that damn plastic gear. Now they have a metal replacement gear for it though. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I just finished doing the "quick fix" on my '00 WS6. Yes, it effects the locks & anything to do with lights & fogs, until you fix the gear.
The "quick fix" is about 10 minutes per side, but will only last so long since you are just moving the worn spot to the up position instead of the down position.
If anybody wants help with this just email me ,,, I got pics from doing mine.
<small>[ September 18, 2002, 06:25 PM: Message edited by: M3EATER ]</small>
