3 10" Sub setup...stereo experts come in please..
-Rob
<small>[ December 09, 2002, 06:36 PM: Message edited by: BAD *** TA WS6 ]</small>
what type of bass you want? tight bass or loud bass? three 10" will give some good tight bass, and it will not be much louder than the 12" two 12" will produce some louder bass becuase the woofer is larger, you may want to research the difference between the 10" and 12" subs,,, another thing to think about, is the "power" to run this type of setup, you need at least 4 gauge wire from the battery, for this box to hold three 10", check the internal volume of each sub, and then pick the best sub that will perform the best in that sub box, i imagine, its going to be alittle smaller than 2 10" sub box for a camaro/firebird, and they have like .75 cubic feet, and that is average for a sub
good luck, if any questions, ask
Thats the box, hopefully. What do you guys think of those Alpine Type-Rs?
Metal/ Rock = 10s are good
Country/ Rap = 12s are good.
However there are some good 12s that can do just about as good of a job for Metal/Rock as a 10 would. I personally think the 12 is the better all-around sub.
