Sub selection
Old Jan 12, 2003 | 01:34 PM
Sears's Avatar
!Dial-up Director
Default Sub selection
Need some help selecting a new sub.
Not sure if I need the dual 4 or dual 2 ohm
Here is a link to the subs
Image Dynamics 12
Headunit is an Alpine 7875
Front stage is Focal 165k2 components
Amp is RF 700x
So what sub do I need the DVC 2 ohm or DVC 4 ohm?
Thanks,
Justin
Old Jan 12, 2003 | 03:20 PM
willinwtx's Avatar
Default Re: Sub selection
if you are getting one sub dvc 2ohm if 2 subs dvc 4 ohm
Old Jan 12, 2003 | 04:36 PM
Sears's Avatar
!Dial-up Director
1 sub
Old Jan 12, 2003 | 06:59 PM
willinwtx's Avatar
ok so get a dual 2 ohm speaker and wire it so it is a 4 ohm load on the amp jump + of one voice coil to - tf yhe other and then use the + and - left to go to the amp, the speaker should come with a wiring diagram on how to do it
Old Jan 12, 2003 | 07:22 PM
Sears's Avatar
!Dial-up Director
Thanks will.
Old Jan 15, 2003 | 05:06 PM
Sears's Avatar
!Dial-up Director
Would this still hold true if I used the remaining 2 channels of the amp to power the one sub? Would that have an effect on the ohm of the speaker?
Justin
Old Jan 15, 2003 | 08:39 PM
willinwtx's Avatar
no, if you are using the front half of the 700x for doors and rear speakers, that can be wired 2 ohm stereo, the rear 2 channels are bridged so it is a 4 ohm mono load , thats why you get a dual 2 ohm speaker. the rockford 4 channel if i remember right has a selection switch for how you are going to run it,2,3,4 channel make sure it is set right, you can run it like that on one set of rca's you dont have to run two
Old Jan 16, 2003 | 07:02 PM
Sears's Avatar
!Dial-up Director
Thanks again Will.
Justin
