Guage Install Question
Old Jan 18, 2003 | 11:30 AM
MOBE's Avatar
Default Guage Install Question
Where is the ignition switch wire that you have to tap into? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Also, What 12volt source did you tap into for the lightbulb to get them to come on with the rest of the dash lights?
Thanks!
Old Jan 19, 2003 | 10:59 AM
MOBE's Avatar
Default Re: Guage Install Question
ttt
Old Jan 19, 2003 | 10:29 PM
Xsta Z 28's Avatar
Let's see if the Electronic Guru's can help.
Old Jan 20, 2003 | 02:37 AM
Euclid's Avatar
There's a blue wire on the harness of your head unit. You can use that for your light.
Not sure ont the ignition switch.
Old Jan 20, 2003 | 09:27 PM
ZigZagZ's Avatar
I just installed a pod in my '01 Z-28, with an AutoMeter mechanical guage. The unit is operational, with the exception of the light. I've heard you can tap into the dimmer switch circuit to hook it up. The back of my dimmer switch has 4 wires coming out of it; 1 Green, 1 Grey, 1 Black, and 1 Brown. Any ideas on which one to slice into to supply power to the bulb?
Old Jan 20, 2003 | 09:37 PM
Racehead's Avatar
Just use a 12v test light. Turn the lights on and probe each wire on the dimmer wheel until you find the one that dims your test light when you operate the dimmer wheel. I just did mine, but don't remember what color the wire was.
Old Jan 22, 2003 | 03:10 PM
Biochem's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ZigZagZ:
<strong> 1 Green, 1 Grey, 1 Black, and 1 Brown. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I want to say Brown... at least I'm pretty sure it was on my 84.
Old Jan 22, 2003 | 04:54 PM
Jake99SS's Avatar
I'll have to confirm this but I think I tapped into the #9 and #16 fuses on the panel inside the door. One is the power to the instrument cluster and the other is the dimmer.
Old Jan 25, 2003 | 08:41 PM
ZigZagZ's Avatar
Hey Racehead,
Thanks for the tip. I was able test each individual wire on back of the dimmer switch with a 12V test light. The connector on the back of the switch has a plastic cover that that unsnaps to gain access to each of the 4 wires. I was able to trace the "dimmed" instrument panel wire with this method. Thank again.
ZigZagZ
P.S. It was the green wire.
