stealth box info...
Old Jan 25, 2003 | 03:23 PM
lucky_topher's Avatar
Default stealth box info...
i'm sure i'm not the first who has asked.. but i can't find the info anywhere.. i have too little money and too much time (got laid off and the market sucks)... i want to build my own driverside 10" stealth box... anyone got the dimensions? or can give me stats so i can 'form my own'?
Old Feb 5, 2003 | 08:55 AM
ws6-speed's Avatar
Default Re: stealth box info...
If you want, I can snap a picture of mine with all the dimensions on it. Basically, the hardest part is the face. The rest is just as big a tube as you can fit back there. You will either need to use fiberglass or use flexible plywood to create the rear portion.
Just drop me an e-mail if you want the pics/dimensions.
Russ
Old Feb 5, 2003 | 09:26 PM
MadIceV8's Avatar
Customizing Director
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by lucky_topher:
<strong> i'm sure i'm not the first who has asked.. but i can't find the info anywhere.. i have too little money and too much time (got laid off and the market sucks)... i want to build my own driverside 10" stealth box... anyone got the dimensions? or can give me stats so i can 'form my own'? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was gonna post the same exact thing! I'm basically the same way, but I still have a job... but not a good one at that.
Old Feb 5, 2003 | 09:42 PM
yes, pictures would be most delighted.. either host them (someone else apparently wants them).. if you could give us some approximate measurements of the straight-edges that would assist me in building one... or email them to me at christopher@lifeinwidescreen.com and i'll host them on my website..
Old Feb 6, 2003 | 07:29 AM
ws6-speed's Avatar
I'll try to remember to post some pictures tonight when I get home. I'll take measurements as best I can and add them to the photos. I should warn you though that the main volume of the box is a cylinder, not a rectangle, so building it will be a bit tricky.
Russ
Old Feb 6, 2003 | 09:56 PM
ws6-speed's Avatar
here is the photos I promised:
http://www.anycities.com/user/trpltongue/subbox.html
Have fun,
Russ
Old Feb 6, 2003 | 10:32 PM
MadIceV8's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ws6-speed:
<strong> here is the photos I promised:
Have fun,
Russ </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for helping us out! Good pic's and measurements, hpe I can get mine looking as good as JL's <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> .
Old Feb 17, 2003 | 02:20 PM
MadIceV8's Avatar
ws6-speed - Can you please measure the overall height of the box from top to bottom? This would help me with the measurements of the angle's. This way I can figure out the degree of the left and right angle. Thanks, and the sooner the better since I'm working on sketch of the box on paper as we speak <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .
<small>[ February 17, 2003, 02:21 PM: Message edited by: MadIceV8 ]</small>
Old Feb 18, 2003 | 11:01 AM
Scalpel's Avatar
Have fun,
Russ </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Can you list the parts you used to do it?
Old Feb 19, 2003 | 02:37 PM
MadIceV8's Avatar
ttt
Old Feb 19, 2003 | 02:38 PM
ws6-speed's Avatar
I can measure the box from top to bottom, but you should just measure from the shelf in the car to the sail panel. It should fit completely inside(something like 12 3/4").
Also note, the depth of the cylinder should be 5 3/4" not 6 1/4". I have had some issues mounting the box due to the metal flange on the wheel well hitting the box.
The parts are just standard mdf for the flat cuts and flexible plywood for the cylinder.
You should use cardboard for the face before you go cutting wood. Trim it up to fit exactly then cut your wood to match.
Russ
<small>[ February 19, 2003, 02:43 PM: Message edited by: ws6-speed ]</small>
Old Feb 19, 2003 | 03:51 PM
MadIceV8's Avatar
<strong>You should use cardboard for the face before you go cutting wood. Trim it up to fit exactly then cut your wood to match.
Russ </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks again, and I've been doing the cardboard thing <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> .
