replacement sail pannel subs?
Just wonderin' if any of you guys have bought any after market sail pannel subs?
They just can't take a beating.
What's out there and will I need a new amp?
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
A good 6.5" sub is made by Tang Band: http://www.partsexpress.com/pe/showd...number=264-832
This will blow the stock crap away, but they are not going to run with quality 10"s or 12"s
Edit: actually, probably too deep?
I think those are too deep but I'd also worry about the fact that they are 4 ohm and not very efficient. If he keeps the monsoon amp the subs will only play 1/2 as loud if using a 4 Ohm speaker and with the senstivity of 83db 1W/1m it is going to take a lot of power to drive those subs to anything above moderate volumes.
What's a Sticky?
Just put in some 8" subs hooked to an amp and call it a day....lol.
I put 8" rockford fosgate stage 1's back there and they sound awesome. I'm only feeding them 50 watts right now, so when I get a bigger amp for them and dynomat behind them, they should sound even better. These will require some cutting though...
((((((Administrator))))))
Originally Posted by knight rider WS6
So there's no replacement 6.5 subs that are 2ohm?
![](http://img.photobucket.com/albums/v483/CRAGER01/CRAGER/Parts/DSC05081a_800.jpg)
The Camaro's have a single voice coil 2ohm speaker. Really the only 2ohm in T/A's are the door speakers (woofer's) and thats it.
But sorry man, I don't know what speakers to replace them with. After messing with my Camaro's speakers too much, I am ready to replace the whole system. And when the time comes on my T/A I will do the whole system as well. Stock systems blow ***!
Peace,
Craig.
the eu's will require cutting. i.e. the surround is too big.
read this. http://www.ls1.com/forums/showthread.php?t=21399
most people will tell you to go with stockers for now. until you plan to upgrade. but i'm a personal fan of doing 8"s.
![](http://memimage.cardomain.net/member_images/1/web/2329000-2329999/2329723_32.jpg)
What's a Sticky?
What's a Sticky?
I don't have a pic. but basically, i coverd the back wall, and covered the hole on the side. i don't know if it was "right" but, that's what i did.
