Monsoon Help
The wiring harness is plug and play, basically. you match the colors from the radio to the harness, and plug it into the factory wiring. there' will be an extra plug. that's for the cd changer. don't worry about it.
if you don't want to do a huge system, then you can still use the stock wiring with the aftermarked speakers. basically, remove the old speaker, put butt connectors on the wire ends, and hook them up to the new speakers. the front speakers will require slight modification to adapt to the monsoon amp. not a huge deal.
most people will tell you to keep "stock" 6.5 sail panel speakers. i.e. buy new ones if the current one's are busted. if you want to do something different, you can try aftermarket 6.5's or as I did, 8"s. but then you run into Ohms etc....
the back speakers are 4" full range speakers. basically, the same as the front, only no modification is needed to the speaker itself. hope this helps a little.
If i decide to do a rewire what is all involved in that? does anybody have a wiring diagram or something similar?
http://www.ls1.com/forums/showthread.php?t=20319
i wouldn't rewire just yet though. but basically, with the front 6.5's you get a two way speaker. then you have to unwire the tweeter from the speaker, and wire it to the stock wiring, and wire the mid to the stock wiring. there's four wires going to the front two speakers. one for the mid one for the high. what i did, was solder speaker wire to the tweeter wire and put butt connectors on the ends, and butt connectors on the end of the factory wire, and pluged then together. and pluged the mids wire to the speaker.
EDIT: i just joined up over there. thanks for the help. looks like a pretty compicated rewire. i think i'll stick to this for now.
