Pass side window/wiring problems
Old 09-11-2006 | 11:47 AM
Z'mnypit's Avatar
Originally Posted by WhiteBird00
Programming instructions are in your owner's manual and posted here. You change the "Theft Deterrent Arming Method" to mode 1 to disable the alarm and to one of the other modes to enable it.
Ok, I think I may know why the alarm does that now. I pulled the radio fuse to keep the door ajar ding ding from going off. Is there a way to reset this. Ive put the fuse back in and it activates its self. Ive even un hooked the battery cable then re attached with no luck.
Old 09-11-2006 | 06:42 PM
2001NBMZ28's Avatar
Originally Posted by Z'mnypit
Thanks! Ill get on it... Let me know if the switch fixes your problem!
Replaced drivers side switch module today, took 10 seconds - works like a charm now.
Old 09-11-2006 | 08:01 PM
Z'mnypit's Avatar
Ok heres a list of what I come up with:
- Light blue wire on Drivers side switch for pass side doenst get power any way I try it
- Tan wire on drivers side pass switch gets power when press down
- Pass side tan wire on the pass side switch gets power when grounded to the body and I press down on drivers side switch.
- Pass side light light blue wire get no power anyway I try it. Grounded using the tan or the body.
-When using Tan as a ground and light blue for power asd pressing the button on the drivers side I get no power
- When using Tan as power and light blue as ground and pressing the drivers side button I get no power
So that sounds like the drivers side switch is messed up right?
BTW- 2001NBMZ28, thats awesome you got your problem fixed that quick, I ordered new switches for both sides so hopefully that will be my answer also.
Thanks!
Old 09-12-2006 | 08:27 AM
WhiteBird00's Avatar
Ungrounded Moderator
Thanks!
Yes, it sounds like the portion of the left side switch where the light blue wire switches between power and ground (circuit 166 in the diagram) is defective. It doesn't provide power to put the passenger's window up using the left switch and it doesn't provide ground to put the passenger's window down using either switch. The right switch still works to put the window up because the power is supplied separately through a brown wire and the ground goes through the tan wire.
Old 09-14-2006 | 05:24 PM
Z'mnypit's Avatar
Ttt....
Old 09-14-2006 | 09:52 PM
2001NBMZ28's Avatar
Got/replaced your drivers side switch?
Old 09-15-2006 | 11:42 AM
Z'mnypit's Avatar
Still waiting on them to get here. MY bad I didnt mean to TTT this, I just now seen that it was a reply in it. That was weird there wasnt one when I ttt it. Oh well.
Old 09-15-2006 | 05:13 PM
Z'mnypit's Avatar
Replaced the switches and works like a charm...
