Need HELP! QUICKLY!!!!
This would be a complete, fuel-cut off type of stall, not a stumble or lope then eventual stall. Just bam dead right off.
Unlike manuals, it is possible and in fact normal for there to be an RPM mismatch between the engine and the input end of the transmission. Whenever this happens, the engine wastes power churning and heating the transmission fluid. As a result, the engine is ALWAYS under load unless you shift to Park or Neutral, thus severing the mechanical link between the the engine and the wheels.
Manuals sever this link all the time; that is what the clutch does. Since they often operate under the same no-load conditions that the idle speed is adjusted under, you don't need to add some RPM to compensate for load like automatics do.
The problem is likely in the item that imposes a load on the engine when you put it into gear; the torque converter.
