shift light?
Old Sep 16, 2006 | 11:55 AM
99LSGUN's Avatar
Default shift light?
hey guys i recently bought a proform shift light and i have everything hooked up right i have the green wire hooked to pin 10 which is a white wire and i have good ground and power...when i first turn the key to on the light blinks so thats a good sign but when i test the rpms to see if the light will come on it wont so i dont know what is going on any help let me know thanks.
Old Sep 16, 2006 | 10:43 PM
nostyta's Avatar
Setup the shiftlight to run for a 4 cylinder, you should be good to go.
Old Sep 17, 2006 | 01:29 AM
98TA Bandit's Avatar
I to have the same tach mine has a mind of its own i have tried different modes and even wired resistors inline so i just mounted a toggle switch on it, and mounted them in the middle vent looks and works great there, good luck post pics!
Old Sep 19, 2006 | 09:43 AM
99LSGUN's Avatar
hey i dont really understand "set it up like a 4 cylinder can anyone give me some details to what i am looking for hahaha there are so many wires in the PCM thanks a lot guys.
Old Sep 20, 2006 | 02:54 AM
nostyta's Avatar
There should be instructions with your SHIFT LIGHT on how to set it up to run on a 4 cylinder, which is what you need to do. It has nothing to do with your PCM.
Old Sep 21, 2006 | 10:31 PM
99LSGUN's Avatar
anyway you could tell me step for step what you did to help me out and save some time? that would be awesome!
Old Sep 21, 2006 | 10:57 PM
ChicagoTransAm's Avatar
Dude.. don't even have the light and it took me 30 seconds to find it on Google... laziness
Clip the orange and brown wire loops to run in 4 cylinder mode
Old Sep 24, 2006 | 01:01 AM
nostyta's Avatar
That sounds right, I was not for sure if that shift light had the wires or not, but that is excactly what I was trying to get across. Thanks.
