2 channel amp question
This wires them up in parrallel, if you have two pairs of 4 ohm components it will place a 2 ohm load on the amp. Not all amps can take this.
I'd suggest you just use the amp on your fronts and run your rears of your deck. Rear fill doesn't need full power, and you've got subs for bass. Fading is more important (imo) than power to those rear speakers.
