!!! New keyless remote entry !!!
Old Oct 20, 2006 | 05:06 PM
STS SUPERCAR's Avatar
Default !!! New keyless remote entry !!!
Does the keyless remote have to be programmed by the dealer to work or is there a series of steps to do this on your own.
Old Oct 21, 2006 | 07:54 AM
Duffster's Avatar
there is a series of steps. don't know the order but you should be able to find it here. something about the key in the ignition and pressing the buttons... i remember it was very simple!
good luck
Just found inthe FAQ section
https://ls1tech.com/forums/showpost....6&postcount=22
Old Oct 21, 2006 | 08:08 AM
XtinctZ28's Avatar
Rehab is for quitters...
Here is a step by step, on installuniversity.com
http://www.installuniversity.com/ins...sity/index.htm
Go to: Install documents (On the left)
Then: Under "Miscellaneous" it is the first write-up.
Should help a lot!
Old Oct 21, 2006 | 12:28 PM
Thanks XtinctZ28
Old Nov 26, 2006 | 02:39 PM
The http://www.installuniversity.com/in...rsity/index.htm did not work for my 2002 Trans am. The dealer said I would have to bring it in and they would hook it up to the computer. Is this true or can I do this?
Old Nov 26, 2006 | 03:00 PM
2001NBMZ28's Avatar
You can do it yourself without the dealer. Should've worked using the installuniversity guide...maybe something else is going on? Did you buy a new remote, battery good...
Old Nov 26, 2006 | 03:11 PM
2001NBMZ28's Avatar
Just reread title of your post - if you bought one plug the FCCID number into here: http://autotechs.com/fcc/fccidsearch.htm
Old Nov 26, 2006 | 03:21 PM
Mike02Z's Avatar
Yea, if you bought a compatiable transmitter the installuniversity guide will work (I've done it myself many times). If you bought a fob that is not compatiable with the 4th gen fbody's I don't think even the dealer can help you with that.
Old Nov 26, 2006 | 08:08 PM
Thanks guys it worked this time, I think I removed the fuse one step early the first time.
