Manual override switch for EWP question
So your choice of two or three terminal switch depends on whether you want a light in the switch or not.
I assume you want to set up your EWP so that it is running whenever the car is on and also have the ability to run the pump for a while with the car off. This is easy to do without a switch. Connect the pump using an ordinary 30-amp automotive relay so that it runs off of constant (battery) power but have the relay triggered by an ignition controlled accessory circuit. To do this, connect terminal 30 to battery power (get it at the junction box on the left fenderwell), terminal 87 to the power lead of the pump, terminal 85 to ground, and terminal 86 to an accessory power source. The accessory power source will probably have to come from inside the car because I don't know of any accessory power source under the hood. You can tap in at the BCM, the radio, or the fuse panel to get accessory power. Make sure everything is fused!
This arrangement has the pump running whenever the ignition is on regardless of whether the engine is running. So if you want to continue running the pump after shutting off the engine, just turn the ignition switch to the ACCY position. It also eliminates the possibility that you might inadvertently leave a separate switch on and drain your battery.
I thought the exact same thing u just said (why do u need a switch if u wire it up to an IGN source.) I would rather just install the switch cause i do plan to learn how to tune my car in the future. But you have helped with alot of info. I think im ready to install the switch. Thanks alot for ur help.
-Ryan
