autozone window motor info
Old Nov 6, 2006 | 08:45 PM
qwikz28's Avatar
Default autozone window motor info
just quickly letting people know, i just installed a dorman window motor in my car and its damn good. it comes with hardware and is a ton more powerful then the siemens and the oem. only downside is it is loud as hell. if anyone does get it, dont bother with that little bracket it comes with, its useless. hope this helps someone
jacob
Old Nov 7, 2006 | 02:44 PM
firebird5134's Avatar
thanks for the advice unfortunettly its about that time to replace my window motor as well.
Old Nov 7, 2006 | 09:01 PM
White 96LT1's Avatar
Same here!
Old Nov 8, 2006 | 12:52 PM
Racer383's Avatar
Same here. I put one in and love it. I would rather have the noise. Now, since I have 2 cars, I only need to install 3 more. lol
Old Nov 8, 2006 | 02:10 PM
qwikz28's Avatar
lol thats funny cause its damn true!
Old Nov 8, 2006 | 02:23 PM
Jordan S.'s Avatar
I have one in my car too and they are a beast. Have an oreillys in my other camaro and its a dog. I've had to pull it up since the day i put it in.
Doorman has Lifetime warrenty too
Old Nov 8, 2006 | 03:48 PM
thingthatgoes's Avatar
Thanks, I am about to do it too. Say, is there alot of riveting when you swap the motor or is it straight forward enough not to worry about doing it myself?
Old Nov 8, 2006 | 06:04 PM
FBDYLVR's Avatar
No riveting required, they give you nuts and bolts to use instead of rivets. I put loc-tite on them so that they'd never come loose.
Old Nov 8, 2006 | 09:34 PM
VIP1's Avatar
Copy & Paste Moderator
Where can I get a Dorman motor?
Does it look any different than the OEM or Seimens?
EDIT:
I think I found their website.
Is this it?
https://www.dormanproducts.com/cgi-b...tegory_list=:0
Item Number: 742-101
Old Nov 8, 2006 | 09:36 PM
RUNINHOT's Avatar
Does this brand window motor go up and down faster than the rest.
Old Nov 8, 2006 | 10:16 PM
qwikz28's Avatar
EDIT:
Is this it?
yes thats the one... it looks the same as the others, but you see that bracket it comes with? dont use it.
and runinhot- yes the dorman is much faster then both OEM and seimens.
Old Nov 8, 2006 | 10:45 PM
zioneffect564's Avatar
i need to replace my motor i think... my drivers side window doesnt go up all the way and i havent rolled it down in forever because it bumps all the way down i dont know if replacing the motor would help it at all but its also really slow..pass side is starting to do the same thing
Old Nov 8, 2006 | 10:52 PM
qwikz28's Avatar
the window regulator probably got unbolted as well. you need to take off your door panels and mess around in there. just look for anything that looks amiss and make a ghetto fix. my passenger side regulator unbolted itself as well, i bolted it back in and the window worked again. you'd be surprised how often those quick, little fixes solve what you expect to be a big problem.
edit: i would recommend replacing the window motor while you have the door panels off anyways. especially if they are old or on their way out.
Old Nov 9, 2006 | 04:04 PM
qwikz28's Avatar
just an update, today was the first day i took my car out since i did the window motor swap. now my friend, who is in my car i'd say once every month or two says, and i quote: "holy crap, your window is fast! what did you do to it?"
Old Nov 9, 2006 | 07:17 PM
DeviLs1's Avatar
So if you dont use the supplied brackets .. What do you do ? reuse the factory brackets ??
Old Nov 10, 2006 | 11:19 AM
john shea's Avatar
Thanks. I was just about to post what the hell is this bracket.
Old Nov 10, 2006 | 11:46 AM
qwikz28's Avatar
if you follow this: http://shbox.com/page/windowmotor.html you wont need the bracket. i assume the bracket is for people who remove the old motor differently. good luck o ye of little fbody experience
Old Nov 14, 2006 | 06:33 PM
m1candelaa1's Avatar
Has anyone ever used the window motors from Ebay that sell for about $11.99? Whats the estimate cost for a window motor
Old Nov 15, 2006 | 07:16 PM
gnomee's Avatar
Hey guys,
If your motor is not dead and just slow you may want to check our kit out.
http://www.autotrix.net
We just started advertising here on Ls1tech and should have our banner up any day now.
Old Nov 15, 2006 | 10:20 PM
VIP1's Avatar
What does this do?
