Can I use the stock amp with my laptop (no head unit)
I want to ditch my head unit and wire my laptop straight to my amp. I've read some people have had problems with the monsoon amp and I just want to have this clarified so I know if I have to buy an amp or not.
I'll be using the stock speakers too if it matters.
Ungrounded Moderator
Well, yes and no. You can connect it but it probably won't work very well. For one thing the Monsoon amp accepts only speaker level input and the headphone jack on your laptop doesn't put out a lot of power so you won't get much volume. For another, the amp takes four channels of input but your laptop only produces two channels of output.
Copy & Paste Moderator
Okay that definitely helps. Kind of embarrassed that I missed that post
. I'm going to need a new amp and figure out how to wire it to keep the current ohms (search is broke at the moment) since my laptop sends a low level signal.
Where will I control the volume with a new amp? Will I basically set it pretty high and control it from the computer?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ok so I've been digging a bit and it seems like whenever anyone wants to upgrade their amp they run their own wiring. Isn't there a way to use the stock amps power ground speaker wire? A harness of some kind maybe? I'd like to simply replace the stock amp with an after market amp and probably wire up the remote turn on to the PC power switch.
The factory harness has a "amp is here" wire. I think it tells the stock radio to turn its own amplifier down some. You can use it for whatever you want. On my last head unit I had separate amp and antenna power leads. I ran a turn-on wire all the way myself and used the "amp is here" wire to operate my antenna. At the radio I repinned the "amp is here" wire to match up to my head unit adapter plugs, power antenna wire. At the amp connector I use that lead to trigger the power antenna
You're going down the path that many before including myself have tried to upgrade only a bit at a time but at the end of the day:
- I replaced all stock speakers
- I pulled out the stock amp and use a 2 channel on the fronts.
- I put a sub in the trunk with a pretty big amp dedicated to it.
- I wired both amps from the battery directly to get a decent size power wire feeding the amps.
- I changed head units twice.
Yes you can but such small amps are hard to find, and also cost money. There is a bit of a "ground floor" to amp pricing so by the time you do it, it doesn't really make much sense. Better off just buying an aftermarket amp (used if money is the issue) and being done with it.
How bout just using a switchable FM modulator or line in (if your radio will take one) and running the laptop through that way.
Keep stock look, easy way out.
Right now I have one of those adapters that makes an AUX for the stock head unit. The problem is it sometimes "forgets" it was set to aux when I turn the car off. So when I turn the car back on to get it back to aux mode I have to take my radio bezel off and reach in behind the head unit (I have it in there backwards) and do some un-natural reach
and it's just no fun.
I don't mind spending money to fix the problem and if I had to chose between allot of wiring and a little less money or more money and less wiring I'll go with more money.
I'd really not like to touch the stock amp at all if possible. I'm not the best with car audio and the simpler the solution the better. But, I will do whatever it takes to not have to manually press that stupid button. Being able to teach the stock HU to remember what it was set to would be really nice.
Here's another idea I read about, let me know what you guys think. Could I take a small amp and use that like a pre-amp to the stock amp?
They were mentioned in this forum a while back - I think it was VIP1 that knew the brand but I can't remember that for sure either (man, it sucks getting old).
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
That looks very promising! I searched around with V1P1's name and I came up with this site.
http://www.fadingarrow.com/XMSatelliteRadio.htm
He uses one of those line drivers you mentioned.
http://store.xmfanstore.com/linedriver.html
"The LD-1 will boost the output from 0 to +18db with less than 0.005% distortion." Perfect.
That is exactly what I'm looking for. I'm assuming the stock amp has RCA inputs, but if for some reason it doesn't that'll cause yet another hurdle.
![](http://us.st11.yimg.com/us.st.yimg.com/I/yhst-67720110273938_1923_5681118.jpg)
Okay... great. Can I take RCA cables and convert them into something the stock amp will accept?
Edit:
Any chance this would work? Linky
Edit:
Edit:
Edit:
What type of amplifier does FireWave use?
FireWave is not an amplifier and only supplies line level output. It is designed to be connected to self-powered multichannel speakers or to an amplifier/receiver with discrete inputs.
The Monsoon amp is a special purpose design amplifier for a specific OEM need. Its expecting quite a high input power level and does not have a very high gain setting because its taking stock head unit output and bumping it up. Its set up this way so that cars without the Monsoon don't need to be totally rewired. The Monsoon amp is also not very good overall and adding a whole bunch of active adapters will raise the noise floor a lot. The stock amp has pretty bad hiss already. I wouldn't want you polish that turd too much.
BTW, thats my site (see sig).
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
I think you are barking up the wrong tree with that line level booster. You need to understand the monsoon amp is needing somewhere in the range of 10-20 watts per channel input to put out full output.
You have no way to adjust the gain of the monsoon amp, so this is what you have to feed it to get it to drive properly.
That line level booster looks more like a tool to boost pre-amp RCA outputs from low level (like low quality 0.5v or whatever) to higher, in the range of 3-5v output levels.
I'm strongly recommending you just find a better solution to use your factory aux input. It will give you the best sound quality without spending unneeded money or hacking into all your wiring.
