Can cold weather cause fiberglass not to harden.
my resin that i put on my fiberglass is taking forever to harden. i added enough hardener but its still has taken awhile. its been about 2 hrs now. and the resin is starting to turn a green color. i;ve never had that happen before.
josh
josh
Restricted User
2 hours and you expect it to be cured ?
fiberglass curing is very dependant on temperature.
I usually get 30 minutes to 1 hour of pot life from resin between 60 and 75 degrees, with full cure taking upwards of 3 hours. Anything under 60 will make it take longer, with sub 50 temps taking overnight to cure.
The only time I get 2 hour cure times is in the middle of summer, when I place the layed up part in direct sun light.
resin chaning colors is a natual reaction of curing. what color resin did you start with ? I use a premium blue resin that turns a greenish color as it cures.
well i wasn't expecting it to be cured. its about 40-50 degrees outside and i applied all the resin at about 12:30. but its not a jelly like as it normally is as it hardens.
i used a kinda tannish/ pinkish resin.
cold, cure, curing, fiberglass, fiberlglass, green, harden, hardening, hardens, long, resin, temperature, temperatures, turns, weather
