headlights go dim then back to norm
Old Jan 3, 2007 | 07:25 PM
thecarolinakid~98ss's Avatar
Default headlights go dim then back to norm
ever since i bought my car I have noticed that the low beam head lights will go dim for half a sec then back to full strength.
could this be a battery issue like not enough juice? or did the guy I buy it from do something screwy with the wiring?
Old Jan 3, 2007 | 10:06 PM
HiTechGent's Avatar
Is this a random occurance? Or when you first start the car? When engine idles? Or when you accelerate?
Need more details to diagnose.
Old Jan 3, 2007 | 10:11 PM
OOZ28's Avatar
Watch your voltmeter, and if its dropping under 13 then charging over 13, I'd say it was your alternator going. I just went through two of them, and a word of advice if it is your alternator, Dont buy the duratrash **** from autozone, and dont forget to disconnect the battery before you go wrenching on it!!
Old Jan 4, 2007 | 04:20 AM
ws6dude's Avatar
Mine does that too, it does it every so often and has been doing it since I bought the car
Old Jan 4, 2007 | 10:40 AM
35thUCF's Avatar
mine too, from day 1
Old Jan 4, 2007 | 11:35 AM
MTN_Z's Avatar
Mine does it too. I had flickering lights with the stock one so I swapped in an Autozone one. Now whenever I accelerate, the lights go dim and the gauge drops down. Probably gonna go get one from the dealer.
Old Jan 4, 2007 | 04:19 PM
No it's not a random occurance it has pretty much always done this
I bought the car 6/11/05 with 32,900k on it
Its hard to remember, plus I only notice this at night obviously but I do believe the voltmeter dips a tiny amount and I can here a noise when the light dies down
I really hope that it's not the altenator because I recently brought my car in for a tune up and that ran about $500 after they found that the rear diff had a leak and replaced the diff pinion seal which was about 200 extra than I thought. Then I drove back to school after this was done and my mastercylinder went out another 400 ( always thought it was due to the fact when I had the car tuned up they drained and replaced the brake fluid). Got new tires for christmas 350 there.
So if I need a new altenator is this an expensive piece?
Old Jan 4, 2007 | 08:29 PM
HiTechGent's Avatar
Sounds like a relay kicking in. Probably nothing to worry about.
Old Feb 12, 2007 | 10:37 PM
sleepinghawk's Avatar
Same here. Now around 18000 miles, happens atleast 1 time at night. Just a half a sec. No time to read a gauge.
Old Feb 12, 2007 | 10:59 PM
thunderdan74's Avatar
Yep.
Mine has done it since day 1 also. I have 150,000 miles on her now. I'd say it's not an issue.
Old Feb 13, 2007 | 08:18 AM
dirtyblackhoe's Avatar
Mine does it every once in awhile as well. To me it seems like either a relay or the Electric fans clicking on maybe?
