Desperate for wiring advice!
At this point I’m very very confused and frustrated. I’m pretty competent when it comes to this kind of stuff, but working with something that wasn’t made to work has got me stumped! My questions are as follows…
1. Using the line level output….where should I splice it into? (midbasses in sail, or midranges in rear)
2. Where is the closest source of switched 12v power in the rear of the car? (remote turn on)
I really appreciate any help I can get from you guys....I'd like to get the box built tommorrow (easy)...but i need to get it to make sound first
the best switched 12v power is just gonna be the accessory wire to your ignition. you can rig it other ways but it won't be reliable plus you'll just **** off the next person that owns your car when they try and put a headunit in...
You may be having a problem with your LLC because of overloading. Try connecting to the speaker level inputs at the Monsoon amp rather than the amplified outputs. Then be sure to add a low-pass filter so that you don't pass any high frequency signal to your sub.
then when i ran a wire straight from the + on the battery, it fired right up. maybe its not getting 12v from the antenna?But anyway I'm positive the line output converter is pretty crappy, because it just came with an amp my buddy bought for his exploder....but surely it shouldnt sound this bad....I just want it to sound decent and possibly upgrade later.
as far as tapping wires at the amp...what color/location are they?
well thats all that i can think of now and im sure i'll think of something else, thanks for helpin the newb
OH...and heres some quick pics....
AMP CONTROLS: thinking that I can just use the internal LPF?
http://i80.photobucket.com/albums/j1...1/100_0563.jpg
RESONANT ENGINEERING SE 12 SUB: 600W RMS 1200 PEAK
http://i80.photobucket.com/albums/j1...1/100_0572.jpg
AMP REMOTE (NEVER USED IT?!?!)
http://i80.photobucket.com/albums/j1...1/100_0573.jpg
What Element was saying was if you are using the power antenna output of the factory deck to turn the amplifier on, the factory deck may only supply 12v when the radio portion is on. When the CD portion of the deck is on, the 12v is not present and the amp will not turn on. run a wire to the yellow wire at the back of the headunit for your remote turn on. THAT is definately switched 12v.
Honestly if it were my car, I would be buying a couple of Metra wiring harness that plug into the radio and car. Wire the LOC between them. Read this thread (post# 28): https://ls1tech.com/forums/showthrea...tput+converter
anyone know how I can squeeze more volume out of that thing? (no equalizer adjustment as it also turns up the sails). and also, does anyone know with my remote (linked earlier in thread), what kind of cord do I need? I left my other one in my Jeep when I sold it, and as far as I can tell its just a phone cable. Thanks! No, the factory head unit provides power to the antenna whenever it is on in any mode - radio, CD, CD changer, or tape player.
On most decks I have seen the deck powers the antenna up or down whether the radio function is on or off. I forgot the Monsoon is different.
anyone know how I can squeeze more volume out of that thing? (no equalizer adjustment as it also turns up the sails). and also, does anyone know with my remote (linked earlier in thread), what kind of cord do I need? I left my other one in my Jeep when I sold it, and as far as I can tell its just a phone cable. Thanks!What model of amplifier are you running? From the picture, it looks like you are running one of these amplifiers (manual link): ftp://inform.kenwoodusa.com/manuals/KAC9152d.pdf
The manual doesn't give any information about the cable specifically, but it may just be a straight through 4-wire phone cable with RJ11 ends. But it may have wires crossed internally (like a CAT5 network crossover cable). I would call Kenwood's tech support and see if is a straight through 4-wire cable. If it is, you should be able to use an ordinary phone cable from Radio Shack. If it is not a regular phone cable and you use one, you may damage the amplifier.
