Battery Gauge
Old Jan 27, 2007 | 10:29 PM
Choppers's Avatar
Default Battery Gauge
I just finished hooking my amp and subs up. My battery gauge now stays in the red. Do you think that its my battery?
Old Jan 27, 2007 | 10:46 PM
Gallstaff's Avatar
I'm certainly no expert but did you wire your amp directly to your battery and then crank up your stereo when the car was OFF? If so, that might have killed it.
Old Jan 27, 2007 | 10:50 PM
Choppers's Avatar
no i cranked the car and then i let it run for a few mintes as i was getting my cds so i could put them in the car to listen to and as soon as i started playing the music with the amp and subs on my battery gauge went in the red and stayed there.
Old Jan 27, 2007 | 11:12 PM
Gallstaff's Avatar
Maybe your charge is low or you need a new battery. It seems weird that it would be in the red. What happens when you're actually moving?
Old Jan 27, 2007 | 11:30 PM
JoeKnowsBaseball's Avatar
my battery used to do that and i decided that it was a crappy battery but i never replaced it. it just sat on the low end of the guage.
Old Jan 27, 2007 | 11:46 PM
Gallstaff's Avatar
I'd get a new battery
Old Jan 28, 2007 | 10:00 AM
Choppers's Avatar
Yea I am thinking it's the battery cause it's 3 years old or more. Whatbattery should i get for my car since i have a stereo with amps and subs. Would you guys reccommend a capacitor to?
Old Jan 28, 2007 | 02:01 PM
volcanic2345's Avatar
yellow top!!!!!
Old Jan 28, 2007 | 06:51 PM
Choppers's Avatar
Is the Red top Optima any good. I have a red car so the red top would loook the best. Whats the difference between the red and yellow?
Old Jan 29, 2007 | 06:00 PM
Choppers's Avatar
anybody?
Old Jan 29, 2007 | 06:22 PM
wvaboy's Avatar
red top will meet all your needs!
Old Jan 31, 2007 | 02:14 AM
CaliforniaBoy5's Avatar
red top will meet your needs unless you want to play your music for a LONG time without worrying about draning it. If you will be having the car on most of the time when you listen to music then the RED top will be fine. Unless you have a lot of LED's, and something taking a lot of power then i'd get the yellow if you'll be running them with the car off.
Old Jan 31, 2007 | 04:56 PM
Choppers's Avatar
thanks for the replies guys
Old Jan 31, 2007 | 05:24 PM
Skip01's Avatar
Yes red top def over yellow....yellow will actually fail over period of time if used as a starting battery....happend to me along with countless others....but a yellow top in the back wouldnt hurt u none.
Whats ur current setup if i may ask?
Old Jan 31, 2007 | 06:50 PM
Choppers's Avatar
I have the
Head Unit: Pioneer Premeir 680MP
Front Speakers: Alpine Type S
Rear Speakers: polak audio's
Amp: Profile 200watts rms x2 and peak 800watt x2
Subwoofers: 2 Infinity Kappa 12's
Amp Kit: 4 Gauge wire to the battery
Old Feb 2, 2007 | 02:34 AM
BluLS1's Avatar
i had a red top in a blazer i had and i loved it. if i had to get another it would be a red top. i had 4 aux. 150w spot lights and used it on high beam and left it all on for a good while and when i went to crank it it started up without a hesitent.
