Battery?
Old Mar 8, 2007 | 03:59 AM
DD966's Avatar
Default Battery?
So, I've added a 4-channel amp, sub-woofer & amp... among other things (nitrous ) and I am thinking about replacing my battery. Recommendations? Please do not tell me to do a search Thanks in advance.
Old Mar 8, 2007 | 04:00 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Optima red or yellow top...
Old Mar 8, 2007 | 09:04 AM
WhiteBird00's Avatar
Ungrounded Moderator
Did you do a search?
It depends on how you use the car and how much you want to spend. I agree that Optima batteries are among the best you can buy. For normal use get a red top. If you like to run your system often without the engine running then you might want a yellow top. They don't have as much cranking power but they are designed to "deep cycle" - you can discharge and recharge them many times without damage.
If your charging system is in good shape then you can buy any battery that fits if you don't want to spend the money on something like an Optima. Just don't buy an OEM GM replacement - they're prone to case cracking and aren't as good as others you can get for the same money.
Old Mar 8, 2007 | 09:23 AM
95bat's Avatar
Yeah the new AC Delco batteries started leaking too.
Old Mar 8, 2007 | 10:00 AM
dragonrage's Avatar
Keep your stock battery unless it needs to be replaced already or you plan to play the system with your car off. If your lights dim and stuff, get a new alternator, period. I've heard reports of yellow tops not lasting long... And if you do get a battery, convert to top post instead of side post. Much more durable.
Old Mar 9, 2007 | 06:26 AM
wickedwarlock's Avatar
Yellow tops work just fine. Any deep cycle battery works fine. Just becuase there's one bad apple, doesn't mean the whole batch is bad.
Old Mar 21, 2007 | 05:28 PM
The PAT WS6's Avatar
where can i buy a red top battery at?
Old Mar 21, 2007 | 05:29 PM
1QUIKWS6's Avatar
You can buy them right off the shelf at Advance Auto or PepBoys
Old Mar 21, 2007 | 06:49 PM
green28's Avatar
So your saying to stay away from the AC Delco's? I was going to have my brother pick me one up tomorrow. He can get them for $64 through work and that sounded like a decent price to me. My stocker lasted for 8 years but it's time for a new one and I was planning on replaceing it with another AC Delco.
Old Mar 21, 2007 | 07:05 PM
You had a Delco battery last 8 years???? Man, are you lucky! Really, don't buy another Delco. If you don't want to spend the money on something like an Optima, there are several better choices in the same price range. Sears Diehard comes to mind. Champion also makes good batteries.
Old Mar 21, 2007 | 07:17 PM
slikrider20's Avatar
When your engine is running, all of your power is coming from the alternator. when your engine is off, obviously all of it is coming from the battery. Alternator's and battery's work together, get a good alt and a good batt and you'll be set. However i'd get an alternator way before a new battery. Just go to walmart and get an everstart maxx, that's all you'll ever need unlesss you decide to keep your system running for long amount of time with the engine off, but who does that anyway?
