Voltage Needle moves a lot...
Old Mar 16, 2007 | 09:07 PM
LoWeLL216's Avatar
Default Voltage Needle moves a lot...
The voltage needle on my gauge cluster almost looks like it's vibrating when I'm driving. Sometimes it stays fixed, but often not. Also, when my turn signals are on the voltage needle drops with each "click" then goes back up. Is this normal or is my battery / alternator having issues? I just don't ever remember it doing it before...
Old Mar 16, 2007 | 09:44 PM
dragonrage's Avatar
Sounds like bad alternator or bad wiring/loose connections to me. Check the wiring/connections first.
Old Mar 16, 2007 | 10:02 PM
presto_z's Avatar
get your alternator tested... go to 2 places and have it checked.. alot of the time they will say its good, but it is actually bad... discount auto, autozone, pepboys...ect.. will test it for free
Old Mar 16, 2007 | 11:14 PM
navymitch12's Avatar
check the ground on the back of your drivers head...there are 2 make sure they are tight. Check the rest of the grounds around the engine bay
check the alt
test the battery
Old Mar 17, 2007 | 09:13 PM
SSNISTR's Avatar
Sounds like a bad voltage regulator. Which means time for a new alternator.
Old Mar 19, 2007 | 01:03 PM
wickedwarlock's Avatar
It could be just the guage. Their not known to be 100% accurate. Get out a meter and test it. With a load on it and without a load.
Old Mar 19, 2007 | 03:00 PM
Trent's Avatar
Mine was doing the same thing not too long ago. Turned out to be the alternator.
Old Mar 20, 2007 | 10:23 PM
GPz1100's Avatar
Hook up an analog voltage gauge to the cig lighter or some other source, drive around, observe. If you get similar behavior then indeed its likely the alternator, otherwise probably a bad/corroded connection. As others stated above, check your connections at the battery/alternator to ensure they are tight.
Old Mar 22, 2007 | 04:32 PM
InfiniteReality's Avatar
My car's been doing the same thing for 2 years now. Tested the stock alternator couple of times and always checked out good. I even decided to go with an high output alternator and it did the same thing so I sent it back for another and the problem still remained. Got a refund for the HO when it died during the stall install and put my stock one back on. I've checked everything on mine, re-wired the alternator with heavier gauge wire, heavier gauge ground, checked battery, etc. My Autometer ammeter jumps around when the car is at idle and radio all the way down too, so more than likely it's the alternator. Figured I'd just deal with it until it finally dies........still wait... lol
