What's the red light under the steering wheel to the light?
Originally Posted by realmendrivev8s
What kind of radio do you have in your car. The blue wire is usually the power antenna wire but should not stay on at all times and the amp turn on is usually blue with a white stripe. Id say that your turn on wire may be touching a constant wire somewhere, maybe the wire from the battery is touching the amp turn on terminal on the amp.
Originally Posted by fredmr39
I say pull out that plastic piece and track it down - we all want to know!
I just know that light is on whenever the amplifier is turned on, like when the blue remote wire is connected.
I'll try to pop the headunit out and look around for another wire when I get a chance, or I may just wait for a friend with a test light.
if neither of the blue wires work you can hook it up to the red one too
