Shift Light Help!!!!!!
Old Apr 2, 2007 | 01:45 PM
Freddyrdzls1's Avatar
Default Shift Light Help!!!!!!
Hey People I Bought A Pro-form Shift Light Which Has The Red Power Wire,the Black Ground Wire, The Green Tach Rpm Wire, And A Brown And Orange Wire That Loop From The Shift Light To The Base Of The Shift Light For 4-6 Cylinders.
Well I Got The Power And Ground Wires Connected I Am Having Trouble Connecting The Green Main Rpm Wire .. I Read Instructions But It Does Not Seem To Work.. It Says That I Should Hook It Up On A White Wire In The Passenger Side Firewall But Nothing Happens..
The Orange And Brown Wires It Says That They Are Used On 4 And 6 Cylinders And Not On 99+ Ls1's .
What Would I Have To Do Now , I Called Pro Form Company And They Said To Connect The Green Wire To The White 10th Pin On The Wiring In The Harness Of Computer And To Snip The Brown And Orange Wires So That The Shift Light Would Calibrate.
What Should I Do Now?? Would Appreciate A Respond Thanx Everyone
Old Apr 2, 2007 | 01:48 PM
Ericbigmac83's Avatar
Have you connected it to the 10th pin? That is what youre supposed to do. Is the light doing anythign?
Old Apr 2, 2007 | 10:42 PM
Default re
yeah i connected to the 10th wire but light does not do anything i have it set at 3000 rpm and moved it around to 4000 and up and nothing...what about the orange and brown?? what should i do cut them so they wont interfere or what?? thanx
Old Apr 2, 2007 | 11:55 PM
916LS1's Avatar
I am having this SAME damn problem with the SAME shift light!!! See https://ls1tech.com/forums/wiring-stereo-electronics/687559-major-shift-light-issues.html
I've done everything, snipped the brown & orange wires, and connected the green to the 10th pin. Since I am not the only person with this problem, maybe there was a bad batch of shift lights???
Old Apr 4, 2007 | 02:51 PM
916LS1's Avatar
Can anyone offer some help for us with this problem?
Old Apr 6, 2007 | 12:21 AM
Default snapped
i already snapped both wires (orange) and (brown) "cut" them so that they wouldnt make contact and i connected the green wire to the tenth pin which was a white wire and it still didnt work .... what can i do now ??? anyone???
Old Apr 6, 2007 | 01:45 AM
SweeTbone's Avatar
You shift light has to be set in 4 cylinder mode. I'm kinda perplexed about the brown and orange wire you're talking about. My Raptor has 3 wire hookup. Power, Ground and Tach. Cylinder select is on the light itself. Hook it up as if you were doing 4 cyls.
Old Apr 7, 2007 | 04:28 PM
hey i got my shift light working yeah its the tenth white wire in the fire wall passenger side only 3 white wires in that same connector try all three and it will work about the orange and brown wires, i just cut them so they wouldnt be making contact and it worked great... try that
Old Apr 8, 2007 | 09:08 PM
916LS1's Avatar
I've now done all of this, but it still doesn't work. I used a multimeter to check my ground and power wires, and connected to the #10 white wire. I am totally stumped, this isn't supposed to happen to someone capable of installing a cam
Old Apr 14, 2007 | 04:57 PM
916LS1's Avatar
Freddyrdzls1, how did you splice your wires? Did you crimp or solder? This POS still isnt working, and I've done everything you did...The store I bought it from says they won't take it back if I "install it myself"
Old Apr 20, 2007 | 09:41 PM
Default re shift light
sorry for the super late response but on the wires, i just cut both loops so they would not make contact... make sure your ground, and power are working... sounds weird but yeah cut the both wires so that they do not make contact the only ones connected will be the green, power and ground.
oh yeah once you cut them, try all 3 or 4 white wires in the firewall fender well ... i tried all of them untill finally the shift light turned on .... let me know whats up ..
