Delco 10 cd changer install in my casset only
My b4c has only a factory casset player in it.How big of a deal is it to install a factory Delco 10 cd changer in the trunk?(like the Z/28s come with)
Ungrounded Moderator
Once you have all the pieces (changer, brackets, harness), it's a simple plug-and-play installation. The harness (if it isn't already installed) plugs into the back of the radio and runs down the left side of the car under the door sill panel to the hatch area. The changer mounts to the floor in the space to the left of the t-top storage area although you'll have to do a little work to attach the brackets - the factory brackets were welded to the floor. Then just plug it in and load some CDs.
