Tc???
Old Apr 15, 2007 | 08:23 PM
transamfreak01's Avatar
Default Tc???
does anyone no how to keep the TC off so i can remove the button so my switches can go there?
Old Apr 15, 2007 | 09:45 PM
Jeff 97 Formula's Avatar
TCS logic module from SLP....TCS is off instead of on when you start the car (you can still turn it on if you want).
http://www.slponline.com/view_product.asp?P=63015
$72.05 from SLP. Try finding one on eBay, might be cheaper.
Old Apr 16, 2007 | 12:38 PM
ok thanks a lot
Old Apr 16, 2007 | 05:30 PM
No problem.
Interesting to mention (since I have one in my car), when it is installed the TCS is off as long as you immediately start the car. If you wait 2 or more seconds, the TCS will be ON.
Old Apr 18, 2007 | 02:40 PM
damn so if u want to shut it off u have to turn the car off and then turn it on again??? that seems like a pain in the dick
Old Apr 18, 2007 | 07:52 PM
True, but if you're quick enough (not letting the ignition stay on for more than 1 second with the engine off) your TCS will be OFF. I do this all the time, and the TCS is always off if I start my car quick enough.
Old Apr 18, 2007 | 08:35 PM
WhiteBird00's Avatar
Ungrounded Moderator
You mean because it's so difficult to just press the switch?
Old Apr 19, 2007 | 05:58 PM
no read my first post... my switch panel is going there b/c im having 6 switches put in
Old Apr 19, 2007 | 08:07 PM
Well, I received the TCS module as a gift several years ago. Now, I'm really happy I have it since my Sirius Stiletto kinda blocks the switch now.
Old Apr 20, 2007 | 11:23 AM
Gregg_98TA's Avatar
I really should take some time and devise a simple circuit with functionality similar to the SLP device. It really shouldn't take but a few resisters and capacitors.
