o2 ta window probs
Old Aug 1, 2007 | 07:07 PM
bigtim02ta's Avatar
Default o2 ta window probs
on my 2002 ta my passenger side window will go up about halfway sometimes and then quit and u can wait a while and it go the rest of the way. also does the same on the way down
Old Aug 1, 2007 | 08:46 PM
kbronSS's Avatar
mine does the same, probably the motor is dying.....i would guess.
Old Aug 1, 2007 | 11:20 PM
aliensRreal's Avatar
my passenger does something similar. It will go almost the whole way up and get stuck, going down it works perfectly fine most of the time. There has been times where it seems the window just died completely, but that definitely is not as often as the other problem.
Old Aug 2, 2007 | 07:25 AM
Michael02hawk's Avatar
Yup - your window motor inside the pass door is shot.
Needs to be replaced with a new motor AND apply the slow pass window fix from Autotrix. ---->
There kit will prevent the slow death of your new window motor.
Old Aug 2, 2007 | 08:16 PM
pit's Avatar
pit
ive got the same proble . does that auto trix thing really work?
Old Aug 23, 2007 | 09:30 AM
gnomee's Avatar
Yes it does. do a search for AutoTrix you will see tons of threads!
Old Aug 24, 2007 | 09:51 AM
autotrix's Avatar
Closed ex-Sponsor Account
It really works....and once you finish installing come back and post your results!
There are several videos availible here on tech as well as on the website
Old Aug 27, 2007 | 09:47 AM
rmpitzer's Avatar
I would do the AutoTrix fix before buying a new motor. It will most likely solve the problem alone. It did for my car!
